Extracting a sinewave signal when characteristic phase and frequency are known
A sinewave signal contaminated by noise can be analyzed by leveraging known phase and frequency to extract its magnitude. Basic Fourier transforms may shift the phase, complicating magnitude extraction. Suggestions include filtering out noise, peak detection, or calculating the RMS value and adjusting for offsets. The discussion also highlights a method by Tom Irvine, called sinefind, which uses curve fitting to identify amplitude, frequency, and phase. Understanding the nature of the noise, whether Gaussian or normal, is also crucial for effective analysis.
tchetch
Hi there,
i have this problem:
I have a sinewave signal contaminated by a large amount of noise. I already know the phase of the signal and its characteristic frequency, and I am searching for its magnitude.
If I do a basic Fourier transform, I would obtain the magnitude at its characteristic frequency, but the phase would be generally shifted. Does anyone know a way to extract the magnitude at its specific phase and frequency ?
Thanks in advance
Filter out the noise and then do peak detect? Or just take the RMS of the signal, and calculate the peak value (adding or subtracting an offset as necessary)?
I don't understand how a sine wave can have absolute phase?
Is it truly noise or have you considered it could be an aliasing issue? Have you treid playing with the sampling rate?
I was also looking through some old notes I have. Tom Irvine over at Vibrationdata.com published a quick paper regarding a method he wrote a small program for, called sinefind. The paper is entitled "Sine Function Identification and Removal." I can't post it here because it is Tom's work. It pulls out amplitude, frequency and phase by a curve fit method.
If you have any interest in vibration analysis, take a look over at Tom's website.
www.vibrationdata.com
There is a type of numerical filter than can do this, but the name escapes me right now. Is the noise gaussian or normal?
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
