How Do You Simplify Trigonometric Expressions Using Identities?
  • Thread starter Thread starter Olly_price
    Factoring
To simplify the expression (cos^2θ + sin^2θ)(cos^2θ - sin^2θ) to cos^4θ - sin^4θ, recognize that cos^2θ + sin^2θ equals 1, allowing the expression to reduce to cos^2θ - sin^2θ. This can also be approached by applying the difference of squares formula, x^2 - y^2 = (x - y)(x + y), where x = cos^2θ and y = sin^2θ. Expanding this leads to the desired result, demonstrating the utility of the distributive law in algebra. Understanding these identities and methods is crucial for tackling more complex trigonometric expressions.
Olly_price
I'm teaching maths to myself so I don't really have anywhere else to go for an explanation other than here, so I apologise if this seems simple.
How do you get from:
to
cos^4θ - sin^4θ
NOTE: cos^2θ is shorthand for (cosθ)^2 as is with all the other ones as well.
The question could also be asked in reverse (how do I factorise cos^4θ - sin^4θ)
Please bear in mind that I am teaching maths to myself, so it's pretty useless if you don't explain every mathematical step.
Mathematics news on Phys.org
It is just algebra if cos = a, and sin = b, then cos^2 = a^2, and sin^2 = b^2
And to take what coolul007 said a little further, it's a difference of two squares.
In general, x^2-y^2=(x-y)(x+y) and this works for any x and y. So in this case x=\cos^2\theta and y=\sin^2\theta
Hey Olly_price and welcome to the forums.
You should learn about the distributive law and expand out the (x-y)(x+y) in terms of x's and y's and you will end up showing the formula Mentallic described above.
This will help you if you come across more complicated expressions where you need to show a similar kind of (example (x-y)(x-y)(x-y) expanded).
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
