Falling egg question (with energy equations)
An egg with a mass of 5.8*10^-2 kg is dropped from a height of 1.5 meters, and the discussion revolves around calculating its potential energy loss, kinetic energy before impact, speed, and momentum. The potential energy lost during the fall equals the kinetic energy just before impact due to the conservation of energy principle. To find the speed before impact, the acceleration due to gravity (9.8 m/s²) can be used along with the height to derive the velocity without needing time. The community emphasizes that the initial velocity is zero and suggests using kinematic equations to solve for the remaining parameters. Ultimately, understanding energy conservation simplifies the calculations for the egg's motion.
jackamo321
An egg of mass 5.8*10^-2 is dropped from a height of 1.5m onto a floor. Assuming air resistance is negligable, calculate for the egg:
a) loss of potential energy.
b) the kinetic enrgy just before impact.
c) the speed just before impact
d) the momentum just before impact.
So far i have done the potential energy one, and now I am stuck on the others. As the equation for KE is KE=1/2mV^2 but we do not know the velocity. And i cannot find out the velocity because we don't have the time either. So i was just wondering how i would work out b-d as all of their equations require velocity.
Thanks
Jack
Thanks
Jack
I hope you are familiar with the concept of energy conservation. What happens to all that potential energy lost when it's dropped?
oh ok, does that mean that the kinetic energy will be the same as the loss of potential energy then? But still, how do i work out the speed and momentum?
Right, you now have KE before impact, and that KE = 1/2mv^2...
Thanks alot! think I've done it now!
Conservation of Energy is easy. But to clarify, you can still calculate the velocity without it.
The egg has been dropped => initial velocity is zero!
All freely falling bodies accelerate at g which is 9.8m/s2
The body traveled 1.5m before hitting the ground.
You will need two equations and work a little more.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
