Falling object and air resistance
Air resistance slows down falling objects, and the height of a falling object can be expressed with a specific equation. For short time intervals, this equation simplifies to the familiar y = y0 - 1/2gt^2. To find velocity and acceleration, one must differentiate the height equation with respect to time. The differentiation process involves handling the exponential term, recalling that the derivative of e^x is e^x. Understanding power series can aid in simplifying the calculations for small time intervals.
justin016
the effect of air resistance is to slow down a moving object. It can be shown that height of a falling object is given by the following
y=y0-[t+(e^-bt - 1)/b]g/b
a. show that for short times this reduces to the expected expression
y=y0-1/2gt^2
b. Find the velocity
c. Find the acceleration
I really not sure where to start with part a. what does it mean by reduces?
You must replace the exponential with its power series. The power series will be a constant term plus a term with t, plus a t^2 term, plus a t^3 term and so on. For small times you can ignore the higher power terms. In this case keep only the first 3 terms.
If you aren't familiar with power series, you can look them up in the back of the book or in a reference book with tables of integrals. The exponential one is also given here:
http://en.wikipedia.org/wiki/Power_series
Could you help explain how to find the velocity and the acceleration for the above equation. I know you differentiate it once for the velocity and then differentiate the velocity for the acceleration, but I'm having trouble.
The expression for y is pretty ugly; I would expand it out like this:
Go ahead and try to find dy/dt. I'm sure you can do the constant terms and the one with a t factor. For the exponential, recall that the derivative of e^x is e^x.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
