Falling Object And Sound Takes 3.2sec
3 replies · 3K views · last reply
TomFoolery
A rock is dropped from a sea cliff and the sound of it striking the ocean is heard 3.2s later. If the speed of sound is 340m/s, how high is the cliff?
V0= 0
A=-9.8m/s2
Ttotal=3.2s
Tsound=Y/340
Y0=Height
Y=0 (height at sea)
Y=Y0+V0T+1/2(-9.8m/s2)T2
becomes
-Y0=(-4.9m/s2)*(3.2s-(Y0*s/340))2
I have tried many different solutions, none seem to work. I am convinced that my problem lies in the equation above. Many of my answers are imaginary, so I must have a problem with my (3.2-y/340)2 part.
It seems to me that it all balances out in units, so it should be an arithmetic problem. Yet, every time I run it, I get different results. My best guess was to try:
(-4.9)(3.22-(6.4/340)y0+(1/3402)y02)-y0
It's probably easier to visualize if you set up three equations. One should represent the time it takes for the rock to fall; the second should represent the time it takes for the sound to get back to the top of the cliff; and the third is the total of both times.
TomFoolery:
You appear to have made a sign error in your last equation. The last term should be adding y0, rather than subtracting it. I get two real answers. (I never put any numbers in, so I don't have a numeric answer. I always use only symbols [with the exception of small integers, like 2], so it is much easier to manipulate.)
David
Thanks for your responses, I'll have to try the 3 equation idea and recheck my signs and run both to see if either/both work as I expect them to. This has been driving me nuts.
