Famous Arcsin Formula for e^x / Sqrt[1-e^[2x]] (Scan Paper)
  • Thread starter Thread starter Riazy
    Formula
Riazy
$e^x / Sqrt[1-e^[2x]] (An integral with e^x div by algebraic expressions)(Scan paper)
Ok I will try my best to write this with digital characters: $e^x / Sqrt[1-e^[2x]]
You will see the problem attached on an image below for more details.
e^x is present
When I do a variable switch, I recalled a famous arcsin formula (also listed below on my scanned paper)
See the picture below
[PLAIN]http://img839.imageshack.us/img839/2892/img0003001.jpg
You were right to think that it was an arcsin integral. This is how it is derived:
You have to do substitution it twice and there is a restricting on x.
If your integral became
\int \frac{u}{\sqrt{1-u^2}} du
then just do another substitution like t=1-u2, which would make your integral much simpler.
But if you do that, wouldn't there be a radical in the numerator?
If you let t = 1-u2
Then...
\int \frac{u}{\sqrt{1-u^2}} du becomes \int \frac{\sqrt{t^2-1}}{t} du
Or am I missing something?
If you let t = 1-u2
Then...
You'd need to get dt=2u du, such that u du=dt/2.
how did you make v = sin x = arcsin (v)
Because as far as I am concerned its not appearing in the integral yet
Wait.. Did you use U as e^x and both sin x at the same time`?, both of them up there are u:s then?
Your integral contains an extra 'u' term in the numerator, so you can't really just use the result to get arcsine.
And it should not contain that extra u term.
If you use u=e^x, then du=e^x dx
Your original integrand: e^x dx / (sqrt(1-e^2x))
So you get a new integrand: du / (sqrt (1-u^2)) ... which fits the formula from the back of your head. Planauts basically showed how that arcsin derivative was confirmed.
Next time I should read the entire integral to be done instead of the last one :redface:
