Faraday's Law of Electromagnetic Induction
The discussion focuses on applying Faraday's Law of Electromagnetic Induction to determine the change in the magnetic field affecting a rectangular coil. The average induced electromotive force (emf) is related to the change in magnetic flux over time, with the formula linking emf to magnetic flux and the number of turns in the coil. Given the dimensions of the coil, the area can be calculated, allowing for the determination of the change in the magnetic field. The participants confirm that assuming a uniform increase in the magnetic field simplifies the calculations. This approach effectively leads to a solution for the homework problem.
spoonthrower
A magnetic field is perpendicular to a 0.060 m 0.060 m rectangular coil of wire that has 100 turns. In a time of 0.070 s, an average emf of magnitude 1.5 V is induced in the coil. What is the magnitude of the change in the magnetic field?
My professor has not covered this in lecture yet, but this HW is due tomorrow. Reading the section for myself and looking at the equations, this is what i have come up with so far. Please help me out, thanks.
average induced emf=magnetic flux/time
average induced emf=B(Area)/time
average induced emf=-N(magnetic flux)/Time
Where do i start?
You're on the right track in applying Faraday's law, which relates the induced EMF to the rate of change of the magnetic flux. The flux through each loop equals B*Area; since the area is constant, the change in flux equals Area*(change in B).
Assume that the field increases uniformly and you can calculate the change in B; everything else is given.
got it. thanks.
