FEM for Gearbox Design: Key Input Data for Finite Element Method Analysis
  • Thread starter Thread starter hellovn
    Fem
When designing a gearbox for a milling machine using Finite Element Method (FEM), key input data includes forces, torques, and supports, rather than spindle speeds or load torsion moments. A static analysis is essential to determine the reaction forces at gear mounts, which must then be applied to the FEM model. The complexity of the gearbox layout necessitates a thorough understanding of the load transmission and the various components involved. It's crucial to evaluate not only the gearbox housing but also the shafts, bearings, and fasteners for factors like fatigue and alignment. Utilizing FEM software can simplify the analysis process, but a solid grasp of the underlying principles is necessary for effective application.
hellovn
hello alll
I am designing a gearbox for milling machine. For Finite element Method purpose, what are the input data (such as cutting force, spindle speed or load torsion moment) most influencing to structure of the gearbox? I am using FEM software for calculating the structure of this gearbox
yes what your assumption is correct boundry conditions for FEM
In gearbox,based on the torque transmission, forces will create to the gear support bearings.Further it has transfdered to the housing.If you send the layout of gearbox with load details myself tried to suggest the boundry conditions.
Thanks
Prakash
FEA software is not a magic wand that can analyze an entire gearbox to tell you whether it will survive or not. I suspect that most of your calculations to do with gear stresses and the like will be analytical (or at least done in a gear-specific software package).
You will be able to model something like the gearbox housing in an FEA package, but it's inputs will be forces and supports, not spindle speeds or load torsion moments. You will have to use statics and dynamics to determine reaction forces and torques at specific mounting locations, and put those forces into the FEA model. Depending on the number of gears in the gearbox, you will probably have to split the problem into separate interactions to keep the model manageable.
Here are gearbox in the assembled and simplified. Please give me more advice
As I suspected, its a very complex model with lots of small features and components. You're going to need to have a much stonger understanding of exactly what you're looking for before we can give you useful feedback. "Analyzing it" is way too general, what are you trying to analyze?
Dear new friend,
I am trying to analysis the structure of this box (in the figure 2-simplified). It means this box could (or couldn’t) stand loading capacity during drilling operations. If this box couldn’t stand, where it will break
Thanks
Well, for a static structural analysis your inputs can be forces, torques, accelerations, and supports. Each place there is a gear mounted (or a pair of gears) you will need to determine what the reaction forces at these gears are, and apply them to the case. There will be a lot of up-front analysis to get the FEA model set up properly.
Dear all
Sorry i cannot get in touch with in time.
It seems to be quite complex gear layout,from the attached housing cannot understand how many stages of gears,torque transmission details(also type of gears and details not available)
Its a bit length project.if u want me the guidance send the all details to my mail id so that i can look further...gear layout,gear details,load details like power,speed etc
Thanks prakash
Hi hellovn,
The advice you're getting here is good. You should realize that we can't tell you what the loads are on your machine without a tremendous amount of detail, and I doubt you'll find this forum adequate to discuss all those details - there's just too much detail. Instead, I'd suggest the following overview, and if you have more specific questions you can try asking them as they come up.
In any analysis of a machine like this, perhaps the most simple way of determining loads and stresses on the machine are to break down the various loads individually. For loads imposed by the rotating shafts and gears, start at the electric motor. That motor puts out a torque which is resisted primarily by the cutting tool. So between the motor and tool, the torque creates forces on the bearings inside this box. Assume these are in static equilibrium and then do a static analysis on the loads to determine these forces. For example, the torque produced by the electric motor produces a force on the belt (and subsequent torque) that drives the shaft. That force has to be reacted by the bearings on that shaft and in turn, that shaft has forces on it that are produced by the reaction of gears or pullys on the shaft. Do a static analysis of those forces to determine the loads and direction of loads on the case. You don't need to concern yourself with shaft RPM to determine loads on the case. You need to reduce the entire system that is imposing loads on this gearbox to a set of static loads that are imposed on the various bearing pads and mounting locations of parts on this case.
And don't forget weight. You will need to determine loads imposed by both weight and motor torque on the mounting locations for the case. All of those loads need to be examined. There should be a variety of cases depending on gearing inside the case, so you should be looking at a variety of different load cases.
After you've done the stress analysis, someone needs to evaluate it. It has to be evaluated with various considerations in mind, such as fatigue, material strength, resulting deflections, etc...
If your job is only to do the FEA on the case, then perhaps someone else can provide those forces for you. Normally, a single 'project' engineer is responsible for an overall project, and they may or may not be responsible for providing the load cases to someone that does an FEA analysis of those loads. It would help considerably to explain what your responsibility is and how you're working with others in your company. In fact, I wonder why someone else at your company isn't helping to explain all these things to you. Have you talked to your supervisor? Why are you looking for help on a message board?
Finally, note that as previously mentioned, the reaction loads on the case aren't the only things that need analysis. The shafts need to be looked at, bearings, gears, etc... All of the loads on the various parts should fall out of the static analysis. In addition, the bearings need to be looked at for clearances, thermal movement of shafts, proper alignment, etc... All your fasteners need to be looked at for proper preload, shear stress in threads, forces on them, etc... Lubrication... fatigue of parts ... economics ... casting manufacturability... There's a whole host of things that need analysis. Where does your responsibility start/end and what are you really trying to get out of this discussion here?
A wonderful reply to ur thread Hope forum poster has clear.
A special applause for u such patience and good reply.
Prakash
Dear all
Thanks for all your advice
I am trying to get strong understand about FEM as some people asked me. But more wonderful there are more difficult theory about FEM.
In this model, Can I use FEM software to analysis the structure? Using the software is easy than using formula calculate method?
Again, thanks very much for all of your advice.
Happy Christmas and Happy new year
