Ferrite Rod Antenna: Understanding How It Works
  • I
  • Thread starter bocchesegiacomo
  • Tags
    Antenna Rod
In summary: Electrical Engineering, or at least what is your background in electronics so far? If you are just starting out, that is fine. It's good to be curious and want to learn.
bocchesegiacomo
I can't understand how a ferrite rod antenna works. Someone can explain it to me?
Welcome to the PF. :smile:
What reading have you done so far? Can you post links to that reading, and ask specific questions about the parts you are not getting? What is your background so far in math and physics and EE?
Antennas are somthing studied also in physics. I am new in this forum and i don t know what answers i can post and what not
What is EE?
What is EE?
Here is a tutorial about ferrite rod antennas that I found quickly with Google -- it looks pretty good.
http://www.radio-electronics.com/info/antennas/ferrite_rod_antenna/ferrite_rod_antenna.php
Ferrite rod antennas are used to make short receiving antennas when a normal (half wavelength size) antenna would just be too big. Like for AM radio stations, which are generally using a frequency band around 1MHz, so 1 wavelength is 300 meters. A 150 meter antenna would be kind of hard to fit in your car... :smile:
Nah, you could use a mere 75 meters also...Seriously, I have thought about the problem for hams using mobile antennae, where you have say a 6 foot whip and special matching networks to get say a 20 meter signal to go through a 2 meter long antenna. I thought about the idea of using a small airfoil attached to a long wire attached to the top of the whip and say you have a 3 meter long wire at right angles to the whip and held in space by the air going by the moving car. That would seem to me to reduce the tuning problem. Of course you better stop talking when the car stops:)
Ferrite rod antennas are used to make short receiving antennas when a normal (half wavelength size) antenna would just be too big. Like for AM radio stations, which are generally using a frequency band around 1MHz, so 1 wavelength is 300 meters. A 150 meter antenna would be kind of hard to fit in your car... [emoji2]
I know electronics quite well but i don t know much about magnetic fields, electromagnetic waves and antennas
Likes berkeman
Thank you
I am also able to use differential equations for electronics
Have you read through the link I provided yet? :smile:
Yes i red it a moment ago and i understood
Likes berkeman
I asked you that question because I am interested in wireless transmission of Energy and maybe ferrite rod antennas can be Used for wireless transmission of Energy I have understood that that kind of antennas arent very efficient.
Ferrite rod antennas are commonly use for receive antennas because they are compact. They are not generally used for transmission, because they are not very efficient transmitters of that long-wavelength RF.
As I said in your new thread about wireless energy transmission, don't believe the things that you read that claim high efficiency transmission over distances. That is generally not true.
Ok thank you.but i did an experiment on wireless transmission with resonant coupling and i have seen that the inverse square distance law does not work
Not in the near field, but it does in the far field.
If you have a link to a mainstream paper about wireless energy transmission, you can link to it here and ask specific questions. Do not post any YouTube videos or links to papers by Nikola Tesla, etc. please.
Here there is a photo about the concentration of the field on the resonant coil by wikipedia
Here there is a photo about the concentration of the field on the resonant coil by wikipediaView attachment 218552
That is no help at all.
Go to the References section of the Wikipedia article you are reading, and find the mainstream source for the information you want to discuss please.
Here is the right image
Here is the right imageView attachment 218553
And notice how the two coils are lined up closely, so there is a lot of coupling between them. That is how some electric toothbrushes are charged when placed in their holders next to the sink. That is not far-field energy transmission.
I hope that makes sense now.
Likes davenn
Ok now i understood. I am italian so i don't know some words well.
No worries. I'm 100% sure that your English is much better than my Italian! :smile:
1. What is a ferrite rod antenna?
A ferrite rod antenna is a type of antenna that uses a cylindrical rod made of ferrite material as its core. It is commonly used in radios and other electronic devices to receive and amplify radio signals.
2. How does a ferrite rod antenna work?
A ferrite rod antenna works by converting the magnetic field of incoming radio waves into an electrical current. This is achieved by wrapping a wire coil around the ferrite rod and connecting it to a circuit, allowing the antenna to receive and amplify radio signals.
3. What are the advantages of using a ferrite rod antenna?
One advantage of using a ferrite rod antenna is its compact size, making it suitable for portable devices. It is also more sensitive to magnetic fields, making it effective for receiving weak signals. Additionally, it has a directional reception, which allows for better tuning and filtering of specific frequencies.
4. How do you adjust the reception of a ferrite rod antenna?
The reception of a ferrite rod antenna can be adjusted by changing the direction of the antenna. Rotating the antenna can improve the signal strength and quality. Additionally, adjusting the length and position of the wire coil around the ferrite rod can also affect the reception.
5. Are there any limitations to using a ferrite rod antenna?
One limitation of a ferrite rod antenna is that it is susceptible to interference from nearby electronic devices and metal objects. It also has a limited frequency range, making it less suitable for receiving signals from very high or very low frequencies. Additionally, the reception can be affected by changes in atmospheric conditions.
  • Electrical Engineering
  • Other Physics Topics
