Calculating & Drawing Feynman Diagrams for $\mathscr{L}$
PhysicsGente
I need to calculate <\phi(x_1)\phi(x_2)\phi(x_3)> and <\phi(x_1)\phi(x_2)\phi(x_3)>_{c} and then draw Feynman diagrams when \mathscr{L} = -\left(\left(\partial_{\mu}\phi\right)^{2} + m^{2}\phi^{2}\right) - g\phi^{3} through first order in g.
<\phi(x_1)\phi(x_2)\phi(x_3)> = \frac{\delta}{\delta J(x_1)}\frac{\delta}{\delta J(x_2)}\frac{\delta}{\delta J(x_3)}Z[J]|_{J=0}
<\phi(x_1)\phi(x_2)\phi(x_3)>_{c} = \frac{\delta}{\delta J(x_1)}\frac{\delta}{\delta J(x_2)}\frac{\delta}{\delta J(x_3)}\ln{(Z[J])}|_{J=0}
I find terms of the form <\phi(x_1)><\phi(x_2)\phi(x_3)> and I'm not sure how to multiply the correlation functions. Any hints on how to do that? Thanks.
I should perhaps say that I know how the diagrams look for <\phi(x_1)> and <\phi(x_2)\phi(x_3)> individually but don't know how to multiply them (or what it means to do that).
ANSWER: You put them together (in one diagram) of course! How silly of me D:
To multiply correlation functions, you just add the diagrams together. For example, if you have two diagrams, one representing <\phi(x_1)> and another one representing <\phi(x_2)\phi(x_3)>, then you can just add them together to get <\phi(x_1)\phi(x_2)\phi(x_3)>. This can be done by connecting the external points of the two diagrams together.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
