Feynman field transformations
harpf
I'm trying to follow Feynman's explanation on page 26-10 of Volume 2 of The Feynman Lectures on Physics. He describes the electric and magnetic fields in a FoR S' moving between the plates of a condenser. Feynman writes that we see a reduced E and an added transverse B in S'. I've attached a copy of the figure in question.
The transformation formula provided in the text is E' = γE, because B = 0 in S. My thinking is that, according to the formula, E' increases. This effect is also consistent with the S length contraction in S'.
I am confused. Thank you.
I have attached additional information in the hope that someone will kindly point out the error in my thinking.
You're right, it does. The "reduced" in the text is in error; possibly a typo or a mis-transcription (since the text was originally transcribed from Feynman's actual lectures).
Another way of seeing that E' has to increase is that E^2 - B^2 is an invariant; it's the same in all frames. In frame S, B = 0, so the invariant is just E^2, the square of the electric field. In frame S', moving relative to the plates, B' is nonzero, so E' must increase to keep the invariant the same.
I appreciate your response. Thank you.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
