Fibonacci Operations: Uncovering Weird Properties
  • Thread starter Thread starter willr12
    Operations
The discussion explores a unique property of the Fibonacci sequence related to the squares of its numbers. An equation involving Fibonacci numbers and their squares is tested, revealing inconsistencies when using different starting points for the sequence. The original poster realizes that the Fibonacci sequence traditionally starts with 1 and 1, not 0 and 1, which affects the results. Upon adjusting the equation to account for this, they find that it holds true when starting with 1 and 1. The fascination with the Fibonacci sequence and its mathematical properties remains a central theme throughout the conversation.
willr12
https://mail-attachment.googleusercontent.com/attachment/u/0/?ui=2&ik=ff063a19b0&view=att&th=148f1c9590566f17&attid=0.1&disp=safe&zw&saduie=AG9B_P-_5uo2y5jplL5o_M_vYWte&sadet=1412805844641&sads=ivFuEkpjW55tmUUptu2J4poEUhA So I've been messing around with the Fibonacci sequence and I noticed a weird property with the squares of the numbers. It is as follows:
Kind of a weird property as the operation on the top changes depending on the value of x.
Mathematics news on Phys.org
Very interesting. I have always been fascinated by the fibonacci sequence and the divine ratio.
2 is Fibonacci number 4, and 1 is Fibonacci number 2 (and 3, but let's go with 2). Let's try it out:
(2)^2 + (-1)(1)^2 = 3. 3 / 1 = 3. Is 3 Fibonacci number (2*4 - 2)? Fibonacci number 6? No, 3 is Fibonacci number 5.
I 'dunno man, I think it doesn't hold up.
Just realized my stupidity. This equation has F1=1, F2=1, F3=2...so it starts with 1 and 1 and then goes onward instead of 0 and 1 as the first two terms. I'm working on a new equation that uses 0 and 1 as the first two. However, this equation does hold up when 1 and 1 are the first terms. When 1 and 1 are the first 2 terms, 2 is fib number 3 and 1 is number 1. Therefore the quotient should be 2*3-(3-1)=4, and 3 is indeed fib number 4 when 1 and 1 are the first terms of the sequence.
Me as well.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
