Can a Rotating Magnet Create a Rotating Magnetic Field?
In summary, the question is whether a cylindrical magnet, axially magnetized, would create a rotating magnetic field when rotated around its central axis or in space. There is a difference between the two types of rotation and the equations for magnetic fields were mentioned, as well as a simulation that showed the vector potential rotating but raised the question of whether the physical magnetic field also rotates.
StephenD420
100
Hello everyone,
I have a quick concept question for electrodynamics course. If a cylindrical magnet, axially magnetized, is rotated round its own central axis, axis of symmetry, will this create a rotating magnetic field in the vicinity of the magnet? what if the magnet was rotated around in space instead of around its axis of symmetry, would this create a rotating magnetic field? Or would a diamagnetized magnet work better?
Thanks.
Stephen
Is there a difference between being rotated around it's axis and being rotated in space?
Yes say the cylindrical magnet center is positioned at (1,1,1) then when the magnet rotates around its axis it rotates with the center never leaving (1,1,1) but when the magnet rotates in space it would rotate around (0,0,0), so it would go from (1,1,1) to (-1,1,1) to (-1,-1,-1) to (-1,-1,0) and so on... so yes it is different...
thanks.
Stephen
bump...
Based on your current knowledge of magnetics, what do you think? Remember that you are in the homework section, so please use the template and show the applicable equations and your own work if possible.
This is a concept question as I stated in my first post.
For the equations there are the maxwells eqs:
div E = rho/e0
div B= 0
curl E = -dB/dt
curl B = u0*I + u0e0*dE/dt
I created a simulation using Comsol and the flux lines, the vector potental, did rotate, but the vector potentials are just mathematical constructs, not real, so does the real physical magnetic field rotate?
Thanks
Stephen
1. What is the "field of a rotating magnet"?
The "field of a rotating magnet" refers to the magnetic field that is created around a magnet when it is in motion. This field is a result of the movement of charged particles within the magnet and can be measured and visualized using various scientific tools.
2. How does the field of a rotating magnet differ from a stationary magnet?
The field of a rotating magnet is constantly changing and is more complex compared to that of a stationary magnet. This is because the movement of the magnet causes the magnetic field lines to constantly shift and interact with each other, creating a more intricate pattern.
3. What factors affect the strength of the field of a rotating magnet?
The strength of the field of a rotating magnet is influenced by several factors, including the speed of rotation, the size and shape of the magnet, and the material it is made of. Additionally, the presence of other magnetic or electric fields in the surrounding environment can also impact the strength of the rotating magnet's field.
4. How is the field of a rotating magnet used in practical applications?
The rotating magnet's field has many practical applications, including in electric motors, generators, and magnetic compasses. It is also used in magnetic resonance imaging (MRI) technology, which allows for detailed imaging of internal body structures.
5. Can the field of a rotating magnet be manipulated?
Yes, the field of a rotating magnet can be manipulated by changing the speed of rotation, the angle of rotation, or by introducing other magnetic or electric fields. This allows scientists and engineers to control and utilize the magnetic field for specific purposes in various applications.
  • Electromagnetism
  • Electromagnetism
