Is the Additive Inverse in a Field Always Unique?
In summary: The easiest way to do this is to use the properties of the equal sign. I'll give you a hint for this as well. Suppose you have the equationA = B. Then, by the properties of equal signs, if you have another equationB = C you are allowed to sayA = C All you are doing is substituting in one equation for another. So, when you solve a problem, you want to get all the equations to be equal signs. So, for example, if you do something and you get the equation2x = 6 and you want to add 7 to both sides, you are allowed to say2x + 7 = 6 + 7
JPanthon
Suppose F is a field and a is an element of F . Prove that the additive inverse of a is
unique (and so we may write it as -a). Justify each line of your proof
in terms of the eld axioms
The field axioms.
http://mathworld.wolfram.com/FieldAxioms.html
Given: (additive inverse) for every a in F, there exists a b in F, such that a + b = b + a = 0
Proof
a + b = b + a = 0
a + b = 0 (additive inverse)
b = -a (adding (-a) to both sides)
a - a = 0 (substitute -a in place of b)This proof seems incomplete to me. Have I made assumptions anywhere?
Anything anyone would change?
Also, this is for a first year uni maths course.
thank you in advance
Well, when you say you add "-a" you are sort of assuming that which you are trying to prove. Forget about "-a" for the proof; the book only mentioned "-a" to give the motivation for wanting to prove this is true in a field. What you need to do is start off by saying something like:
Let a be an element of F and let b and b' be additive inverses of a. So, a + b = b + a = 0 and a + b' = b' + a = 0.
Now, using those relations and the field axioms, you need to prove that b = b'.
Thank you for your reply!
Okay, your method makes much more sense, and would prove uniqueness. But, without subtracting a to both sides, how can I re-write b = b' as -a?
Until you complete this proof, forget that "-a" is something that you are familiar with; just act as though "-a" does not exist. This uniquiness thing is essentially telling you "hey, you can write additive inverses as '-a' just as you did with addition of numbers."
So, I'd start by writting:
b = b + 0 (by the definition of 0)
= what does this equal?
= b'
Now, use what you know about b,b' and a to get the RHS of an equation to be b' as above.
EDIT: One last thing to point out, if you have this equation:
a+b = a+b'
you are NOT allowed to do something like this (though it may be tempting):
b + a + b = b + a + b' implies b = b'
Why can't you do this? This "cancelation" idea is not an axiom of a field. It can be deduced, but you haven't proven that yet.
= b'
a+b = a+b'
Thank you again. Does this work?
(1) a + b = b + a = 0
(2) a + b' = b' + a = 0
Let a = 0
(1) b + (0) = 0
[Zero additive]
b = 0
(2) b' + (0) = 0
b' = 0
b = 0 = b'
Therefore, b = b'
Please reply.
Let a = 0
(1) b + (0) = 0
[Zero additive]
b = 0
(2) b' + (0) = 0
b' = 0
b = 0 = b'
Therefore, b = b'
Please reply.
No, this doesn't work. First of all, at best all this does is prove that 0 is the unique additive inverse of 0 (and whether you have proven that is VERY debateable.) You are proving that FOR ALL a in F, the additive inverse of a is unique. So, you are NOT allowed to say "a=0" (or a equals anything, for that matter.) ALL you can assume about a is that it is in F.
Let me give you another hint:
Let a be an element of F and let b and b' be additive inverses of a, that is a+b = b+a = 0 and a+b' = b'+a = 0. Then,
b = b + 0 = b + (a + b') = ...
Now, keep manipulating this until the RHS of the last "=" is " b' ". Then you have proven that b = b'. Now, once you do that, you are going to have to re-write it line-by-line and explain why you can get from one step to the other from the field axioms.
1. What is a field in science?
A field in science refers to a physical or mathematical quantity that is associated with every point in space and time. It can be a scalar field, which has a single value at each point, or a vector field, which has a magnitude and direction at each point.
2. How are fields important in scientific research?
Fields play a crucial role in understanding and explaining natural phenomena. They provide a framework for studying various physical and biological processes, such as the motion of particles, the behavior of electromagnetic waves, and the distribution of forces in the universe.
3. What is the difference between a scalar and a vector field?
A scalar field is defined by a single value at each point in space, while a vector field has both magnitude and direction at each point. Examples of scalar fields include temperature, pressure, and density, while examples of vector fields include electric and magnetic fields.
4. How are fields measured and studied?
Fields are typically measured using specialized instruments, such as sensors and detectors. They can also be studied through mathematical equations and models, which can help predict and understand their behavior.
5. Can fields be created or manipulated?
Yes, fields can be created and manipulated through various methods, such as applying forces, changing temperatures, or using electrical currents. Scientists can also engineer artificial fields for specific purposes, such as in medical imaging or particle accelerators.
