Figuring out motor power needed
To determine the necessary torque for a motorized platform weighing 5lbs with rollerblade wheels, calculations must consider the incline of 10 degrees and desired acceleration of 10 m/s². The force needed to prevent rolling back on the incline is calculated using F = m*g*sin(10), leading to a torque requirement of T = F/0.08m, which should be doubled for safety. It's crucial to ensure that the stepper motor can provide this torque at the required speed of 20 m/s, which translates to a specific RPM based on wheel diameter. Additionally, understanding the power available, defined as torque times speed, is essential for achieving the desired acceleration. Proper torque and power calculations will help in selecting the right motor for the project.
Corporate666
It's been many years since I was doing physics in college, and I am beyond rusty... and I could use a little help.
I am trying to fabricate a little hobby project involving a motorized platform (like a radio controlled car) that I can move at somewhat precise speeds and program relatively precise turns and movement into it.
The idea is to use stepper motors to achieve this. But I really have no idea what torque I will need from the motors.
-Weight of the unit will be 5lbs
-I want to use rollerblade wheels that have a diameter of 80mm
-I want the unit to be able to travel at speeds up to 20meters/sec (ideally)
-I have read that suitable acceleration would be half top speed, so 10m/s^2
-I would like the unit to be able to accelerate at this level on inclines up to 10 degrees
I realize there will be mechanical and electrical losses in the drive system, which I am guesstimating would be perhaps 20%. But I really have no idea where to start figuring out the torque I need. The motors are rated in oz-in.
I am sure this is less complicated than I am making it, but... help! :)
if your 5lb car is resting on an inclined plane of 10deg it would try to roll back. To stop it you would need a force of atleast F= m*g*sin(10) which for a wheel of .08 m equates to tourque of T=F/.08
double that tourqe and you would be fine.
Tourque output of steppet motor decreases with rpm so make sure your motor can provide the torque calculated above at required speed of 20m/s. which for .08 m wheel equates to 20/(pi*.08) rpm.
if you are interested in the acceleration that you will get, then you need to know more than just the torque. You need to know the Power available - that is Torque times the Speed. Doubling the min calculated torque would be a first stab at it but what speeds do you want?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
