Figuring Out Total Kinetic Energy of Rotating Object
  • Thread starter Thread starter marcia888
    Formula
The discussion focuses on deriving the total kinetic energy of a rotating object, combining translational and rotational components. The original formula is K translational + K rotational, represented as (1/2)mv^2 + (1/2)I(v/r)^2. The alternate formula presented is (1/2)mv^2(1 + I/mr^2), which is derived by factoring and substituting the moment of inertia. The key step involves recognizing that I can be expressed in terms of m and r, allowing for simplification to show how both formulas are equivalent. Understanding this derivation is essential for accurately calculating kinetic energy in rotational dynamics.
marcia888
This isn't a homework question, but I'm just wondering how the text in the book gets from one formula to the next.
To figure out total kinetic energy of a rotating object:
\frac{1}{2}mv^2+\frac{1}{2}I (\frac{v}{r})^2
Then the book gives an alternate formula:
\frac{1}{2}mv^2(1+\frac{I}{mr^2})
So I wanted to see how they get from one to the other. So I tried
factor out the 1/2v^2
\frac{1}{2}v^2 (m+\frac{I}{r^2})
almost there. But how do I get a 1 in place of the m? I could divide by m, but then I get
\frac{v^2}{2m} (1+\frac{I}{mr^2})
It works for the right term, but not the left. What am I doing wrong?
You just didn't factor out completely.
You ended up with,
now take out m. i.e. divide both terms inside the brackets by m so that you end up with m outside the barckets.
Alternatively, you could multiply out the alternate formula, and you will end up with the original one.
The alternate formula for calculating total kinetic energy of a rotating object is derived from the original formula by substituting the moment of inertia (I) for the rotational kinetic energy term (\frac{1}{2}I (\frac{v}{r})^2). This can be seen by rearranging the original formula as follows:
K translational + K rotational = \frac{1}{2}mv^2+\frac{1}{2}I (\frac{v}{r})^2
= \frac{1}{2}mv^2+\frac{1}{2}(\frac{I}{r^2})v^2
= (\frac{1}{2}m+\frac{1}{2}(\frac{I}{r^2}))v^2
= (\frac{1}{2}m+\frac{I}{2r^2})v^2
Since the moment of inertia (I) is equal to mr^2 for a point mass rotating around a fixed axis, we can substitute this in the formula:
= (\frac{1}{2}m+\frac{mr^2}{2r^2})v^2
= (\frac{1}{2}m+ \frac{m}{2})v^2
= (\frac{m}{2}+\frac{m}{2})v^2
= mv^2
Thus, the alternate formula can be written as:
K total = \frac{1}{2}mv^2(1+\frac{I}{mr^2})
which simplifies to:
K total = \frac{1}{2}mv^2(\frac{m+mr^2}{m})
This alternate formula is useful when calculating the total kinetic energy of a rotating object, as it takes into account both the translational and rotational kinetic energies.
