Final velocity of a falling object
The discussion centers on the final velocity of a falling object and the misconceptions surrounding it. It clarifies that the final velocity from a height of 2000 kilometers should indeed be calculated as v2 = √2v1, rather than 2v1, due to the initial speed being non-zero during the second segment of the fall. The participants emphasize that while velocity increases linearly with time under constant acceleration, it does not increase linearly with distance. The equations presented illustrate how kinetic energy increases with distance fallen, while potential energy decreases uniformly. Overall, the analysis highlights the importance of correctly applying physics principles to understand the dynamics of falling objects.
pumpui
I was reading The History of Physics by Isaac Asimov, and I came across this passage.
"Imagine a body dropped first from a height of 1000 kilometers, then from 2000 kilometers, then from 3000 kilometers, and so on. The drop from 1000 kilometers would result in a velocity of impact v_{1}. If the value g were constant all the way up, then a drop from 2000 kilometers would involve a gain in the first 1000 kilometers equal to the gain in the second 1000 kilometers, so the final velocity of impact would be v_{1}+v_{1} or 2v_{1}."
I was wondering why it came to 2v_{1}. Wouldn't it be \sqrt{2}v_{1}?
Here's my thinking:
From an equation, v^{2}_{f}=v^{2}_{i}+2gs, then we have
v^{2}_{1}=2g(1000) and v^{2}_{2}=2g(2000), and thus
v_{2}=\sqrt{2}v_{1}.
You are quite right. The writer lures you into thinking the time needed to traverse the second 1000 m is equal to the time needed for the first. It definitely is not, because the initial speed for the first is 0 but for the second it is v1.
Thank you!
Under constant acceleration the V increases linearly with time. V does not increase linearly with distance.
This looks correct:
If we let i = initial height,
the current height H = i - (a * t^2 / 2).
So a * t^2 = 2 * (i - H).
Therefore t = sqrt(2 * (i - H) / a).
If we substitute that into v = a*t,
v = a * sqrt (2* (i-H)/a). Note that i and a are constants, so the only independent variable is the current height H.
In a nutshell: Kinetic Energy will increase linearly with distance (uniform g) because Potential Energy is reducing linearly (mgh). So the speed will increase as the square root of distance fallen.
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
