Find a vector c that bisects the angle
  • Thread starter Thread starter particleaccelerater
    Angle Vector
To find a vector that bisects the angle between two vectors, a = i + 5j - 2k and b = -3i + j + 6k, one must consider the geometric implications of the vectors in relation to a mirror's normal. The discussion highlights the need for visual understanding, particularly in 3D, where the resultant vector from the two original vectors can represent the normal of the plane (mirror). Participants emphasize the importance of vector addition and the relationship between the resultant vector and the angle bisector. The conversation also touches on practical applications, such as adjusting a mirror's angle based on target coordinates. Understanding these concepts can aid in developing a program for laser beam manipulation.
particleaccelerater
any help is appreciated
Find a vector c that bisects the angle between the vectors a = i + 5j - 2k andb = -3i + j + 6k.
particle,
Could you find one if a and b had the same magnitude?
no i have never done anything like this but i can descirbe the scenario to you
this is for program iam writing for a laser beam. two arbitrary vectors represent the two distances from the laser to the mirror and from the mirror to a target. The bisector represents the normal of the plane(really the mirror). From that bisector, i will have to find the angles the mirror is being pivoted and rotated.
( i would much rather you demonstrate it on this example, i can understand it better by seeing the math, but not visually in my head) thanks for any help you can give me
particle,
"i would much rather you demonstrate it on this example, i can understand it better by seeing the math, but not visually in my head"
I'll get to this example when you're ready for it!
From a single point, draw two different vectors with equal magnitudes. Now draw their sum. Does that help?
i can add vectors in 2d ut not 3d
It's precisely the same thing, particleaccelerator. Put the vectors tail-to-head and draw the resultant line. Or, analytically, just add the components.
- Warren
is it -2i + 6j + 4k? just add the components?
Yeap. That is the sum of the two vectors.
The Bob (2004 ©)
will someone just do this example for me so ican understand it, icant see it visually very well
so the sum of two vectors is the bisector of the angle between the vectors?
Might be. Let me think in 3D first.
The Bob (2004 ©)
I believe it would give you the direction of the bisector.
The Bob (2004 ©)
assuming a plane to be a mirror and two vectors coming from the same point on the plane where the point represents the point of reflection on the mirror, does the resultant of these two vectors represent the normal of the plane(mirror). i am trying to figure this out becuase given the coordinates of where the target should be, i have to pivot the mirror horizantally and vertically to make this happen
particle,
You said you can add vectors in 2d. Try it with 2 vectors of equal magnitude (length) and then with two vectors of different magnitude. See if that answers your question:"so the sum of two vectors is the bisector of the angle between the vectors?"
particle,
Ok, I give up! You don't want to learn anything; you just want somebody to do your work for you. If you wait around long enough somebody probably will. But it won't be me.
Good luck!
all i want is for somebody to tell me if my thinking is right
assuming a plane to be a mirror and two vectors coming from the same point on the plane where the point represents the point of reflection on the mirror, does the resultant of these two vectors represent the normal of the plane(mirror)?
I empathsis with jdavel but I am going to see what I can do for particles understanding.
First off, http://descartes.cnice.mecd.es/ingles/Bach_CNST_1/Analytical_geometry/Geometria_8-1.htm might help.
See if that helps. I need to think of a way of describing what you need to do.
The Bob (2004 ©)
Right. I have had a think and here is what I have come up with. This example is in 2D.
Find two points at the end of the vectors in the same way you use co-ordinate for normal equations of y and x.
Use this points to find the mid-point of the line that would join them e.g:
(\frac{x_1 + x_2}{2} , \frac{y_1 + y_2}{2})
Then use this and the origin to find the equation of the line with the second general equation e.g. y1 - y2 = m(x1 - x2).
See if it can be applied to 3D and you are away.
The Bob (2004 ©)
