Find Acceleration of Block: 1250 N, 950 N@70NofW, 1050N@50NofE
  • Thread starter Thread starter FilthyOtis
    Acceleration
To find the acceleration of the block weighing 1250 N with forces of 950 N at 70 degrees N of W and 1050 N at 50 degrees N of E, the forces must first be resolved into their components. The net forces in both the x and y directions are calculated, followed by determining the mass of the block using the weight (mass = weight/gravity). Finally, the acceleration is found using the formula a = F/m, where F is the net force. This approach reinforces the understanding of vector resolution and Newton's second law of motion.
FilthyOtis
Find the acceleration of the block.
the block weighs 1250 N.
it has a force of 950 N pulling on it at 70 degrees N of W and another force of 1050 N pulling at 50 degrees N of E.
This is just a review question at the start of my physics class first year in college. Pretty sure I should know how to do this but I just can't remember. Can anyone help me out with this one? I'm not just looking for an answer I'm looking for steps and why these are the steps so I can once again understand the situation making it easier to remember in the future. Thank you!
Resolve the force vectors into their components and the use F=m \bullet a.
Thanks, I figured it out a while later. got all the net forces and then got the mass and did
a = F / m.
