Solve xy'=2-x+(2x-2)y-xy^2: "Find All Solutions
  • Thread starter Math10
Homework Statement Find all solutions of xy'=2-x+(2x-2)y-xy^2.Homework EquationsNone.The Attempt at a SolutionThe answer in the book is y=1-1/(x(1-cx)).Here's my work:xy'=2-x+2xy-2y-xy^2xy'=-(xy^2-2xy+x)+2(1-y)xy'=-x(y-1)^2-2(y-1)y'=-(y-1)^2-2(y-1)/xu=y-1u'=y'u'=-u^2-2u/xw=uxu=w/xu'=
Math10
301
None.
Here's my work:
xy'=2-x+2xy-2y-xy^2
xy'=(xy^2-2xy+x)+2(1-y)
xy'=x(y-1)^2-2(y-1)
y'=(y-1)^2-2(y-1)/x
u=y-1
u'=y'
u'=u^2-2u/x
And now I'm stucked. Please help me, I've struggled with this problem for a long time.
None.
Here's my work:
xy'=2-x+2xy-2y-xy^2
You lost a minus sign. In the equation before the one above, you have -xy2 that became xy2.
Math10 said:
xy'=x(y-1)^2-2(y-1)
y'=(y-1)^2-2(y-1)/x
u=y-1
u'=y'
u'=u^2-2u/x
I don't have any more suggestions at the moment, but I'll take a closer look in a little while.
BTW, there is no such word in English as "stucked."
None.
Here's my work:
xy'=2-x+2xy-2y-xy^2
You lost more than just the negative on "[itex]-xy^2[/itex]"! You should have
[tex]xy'= -(xy^2- 2yx+ x)+ 2(1- y)[/tex]
xy'=x(y-1)^2-2(y-1)
y'=(y-1)^2-2(y-1)/x
u=y-1
u'=y'
u'=u^2-2u/x
Math10,
After you fix your algebra errors, with your substitution you should have an equation in x, u, and u'. Try the substitution w = ux. That should get you a new DE that is separable.
Let me try.
Here's my work:
xy'=2-x+2xy-2y-xy^2
u=y-1
u'=y'
u'=-u^2-2u/x
w=ux
u=w/x
u'=w'
w'=-(w^2/x^2)-(2w/x)(1/x)
w'=-w^2/x^2-2w/x^2
w'=(-w^2-2w)/x^2
dw/(-w^2-2w)=dx/x^2
dw/(-w(w+2))=dx/x^2
A/-w+B/(w+2)=1
A(w+2)-Bw=1
A=1/2, B=1/2
(-1/2)ln abs(w)+(1/2)ln abs(w+2)=-1/x+C
(-1/2)(ln abs(w)-ln abs(w+2))=-1/x+C
ln abs(w/(w+2))=2/x+C
w/(w+2)=Ce^(2/x)
w=Ce^(2/x)(w+2)
w=wCe^(2/x)+2Ce^(2/x)
w-wCe^(2/x)=2Ce^(2/x)
w(1-Ce^(2/x))=2Ce^(2/x)
w=2Ce^(2/x)/(1-Ce^(2/x))
u=2Ce^(2/x)/(x(1-Ce^(2/x)))
y=1+2Ce^(2/x)/(x(1-Ce^(2/x)))
This doesn't match the answer in my book. Please check my work carefully and tell me where I got wrong if I'm incorrect.
Math10 said:
u=w/x
u'=w'
You didn't mean that, right?
So where did I make a mistake? What's wrong?
Math10 said:
u=w/x
u'=w'
You're treating x as if it were a constant - it's not. Instead of working with the equation, use the equivalent equation w = vx. Now, what is w'? What differentiation rule should come to mind?
Let me try.
I see how I got it wrong.
So with the substitution w=ux,
u=w/x
u'=(xw'-wx')/x^2
(xw'-wx')/x^2=-(w^2/x^2)-(2w/x)(1/x)
(xw'-wx')/x^2=(-w^2-2w)/x^2
Now what should I do?
u=w/x
u'=(xw'-wx')/x^2
and x' equals what?
There is a fairly obvious cancellation.
So I got
xw'-wx'=-w^2-2w
wx'=xw'+w^2+2w
x'=(xw'+w^2+2w)/w
x'=w'/u+w+2
Now what?
Math10 said:
So I got
xw'-wx'=-w^2-2w
I ask again, what is x' equal to? Think about what it means.
x'=w'/u+w+2
There's no point in reintroducing u.
x'=w'x/w+w+2
Isn't it?
Why did you make it harder on yourself by solving for u again? It's a lot simpler to differentiate the equation above than the one you have below.
And think about what you're doing. You're differentiating with respect to which variable?
Math10 said:
u=w/x
u'=(xw'-wx')/x^2
Math10 said:
x'=w'x/w+w+2
Isn't it?
No.
What does x' mean?
The assumption for the beginning was that y was a function of x.
y'=dy/dx.
So w'=ux'+xu' and what do I do next?
What is x'?
By that, I mean what does x' mean?
Math10 said:
Here's my work:
xy'=2-x+2xy-2y-xy^2
u=y-1
u'=y'
u'=-u^2-2u/x
w=ux
u=w/x
u'=w'
w'=-w^2/x^2-2w/x^2
w'=(-w^2-2w)/x^2
dw/(-w^2-2w)=dx/x^2
dw/(-w(w+2))=dx/x^2
A/-w+B/(w+2)=1
A(w+2)-Bw=1
A=1/2, B=1/2
w/(w+2)=Ce^(2/x)
w=Ce^(2/x)(w+2)
Your work above is what we call a "wall of text." I don't see a single space anywhere in your equations. This makes it much more difficult to understand what you have written. You can make things more readable by inserting spaces around addition and subtraction operations, and around '='.
Here's one of your equation with some spaces added:
w = wCe^(2/x) + 2Ce^(2/x)
If you want us to help you, put some extra effort into making it easier for us to do so.
1. What is the general form of the differential equation?
The general form of the differential equation is xy' = 2 - x + (2x - 2)y - xy^2.
2. How do you solve for all possible solutions?
To solve for all possible solutions, we need to first rearrange the equation to separate the x and y terms. Then, we can use techniques such as separation of variables or integrating factors to solve for y. Once we have the general solution, we can plug in initial conditions to find the particular solution for a given set of initial values.
3. Can this differential equation be solved analytically?
Yes, this differential equation can be solved analytically using various integrating techniques. However, for more complex or nonlinear equations, numerical methods may be necessary to find solutions.
4. Are there any special cases or restrictions in solving this equation?
There are no special cases or restrictions in solving this equation. However, when plugging in initial conditions, it is important to ensure that the solution does not result in a division by zero or a negative value for y.
5. Can this differential equation be applied to real-world problems?
Yes, this type of differential equation can be applied to various real-world problems, such as population growth, chemical reactions, and radioactive decay. However, it is important to accurately model the problem and choose appropriate initial conditions to obtain meaningful solutions.
