Find amount of work necessary to extra 4000J from a body
  • Thread starter Thread starter mahdert
    Body Work
mahdert
Find the minimum amount of work required to extract 4000 J of heat from a body at 0 deg F, when the temprature of the environment is 100 deg F.
W = (1 - t2/t1) * Q1
My answer is 1072 J
instructor says 870.19, how??
Hi mahdert, welcome to PF. According to your equation, it should take the same amount of work to transfer heat between reservoirs at 0K and 100K as it would for reservoirs at 0K and 200K. So right away it's clear that this is the wrong equation; you can't get transfer any hear from a reservoir at 0K.
Also, note the units.
The unit for the temperatures, you mean. I expressed them in Farenheits (deg F)..That will be t1 = 310.92 K and t2=255.37 K. Since heat is being drawn from a body with a lower temperature than the resevour, we need to supply work. The minimum amount of work would be what we would need for a carnot cycle. And I believe that is the correct formula. The answer I got now is 795 J.
0^\circ\mathrm{F}\neq 273\,\mathrm{K}, and it's not the correct formula. Think of it this way: you're removing Q amount of energy and Q/T_2 amount of entropy from the cold reservoir, and all the entropy goes into the hot reservoir: (Q+W)/T_1. At best (maximum efficiency in a Carnot cycle), these entropy amounts are equal. Solve for W.
EDIT: OK, I see you caught the temperature error.
thanks for the explanation.. i understand now..
Great!
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
