Find angular acceleration using theoretical values
The discussion revolves around calculating the angular acceleration of a rolling tin can using theoretical values, including its mass and radius. The original poster has access to experimental data, including angular velocity and time, but is seeking guidance on how to proceed with the calculations.
  • The original poster considers calculating linear velocity from potential energy and then using it to find angular velocity. They also explore using torque and moment of inertia but express uncertainty about the force involved, particularly regarding friction.
  • Some participants question the conditions under which the angular acceleration is being calculated, specifically whether the can is rolling down an incline.
  • One participant suggests using angular momentum relationships and expresses confusion about the implications of height change on velocity.
  • Another participant raises concerns about the moment of inertia used, questioning whether the can's hollow nature affects the calculations.
The discussion is ongoing, with participants exploring various approaches to the problem. Some guidance has been offered regarding the use of equations and the importance of specifying the axis of rotation. There is a recognition of the need to clarify the moment of inertia based on the can's structure, and participants are actively questioning assumptions related to friction.
Participants note the lack of information regarding friction and the specific conditions of the rolling can, which may impact the calculations. There is also mention of the need for clarity on the moment of inertia based on the can's hollow design.
Thynazgul
I'm doing a coursework where I must find the angular acceleration of a rolling tin can using theoretical values. I have its mass and radius. I actually have experimental data so i have access to the actual values of angular velocity and angular acceleration, as well as time.
v= angular velocity * radius
acceleration = torque / moment of inertia
moment of inertia = 1/2mr2
v= square root (gh)
angular acceleration = change in angular velocity / change in time
Torque = force * radius
I'm really stuck but I thought of calculating the linear velocity by using mgh= 1/2mv2, then using the velocity and radius to calculate the angular velocity. Once I have that I could calculate two angular velocities and use the time between them to measure the acceleration.
Another attempt was to use a = torque / I and try to calculate the torque but I don't know what force to use. I believe it could be friction but I do not have information on friction.
What exactly is the condition for which you are trying to calculate the angular acceleration? I assume that the can is rolling down an incline, but that isn't clear from your post.
Exaclty, sorry I forgot to mention that.
Since I have a measured value for linear velocity I've been playing around with angular momentum,
since L= Iω and L=mvr
then Iω =mvr
ω=mvr / I
maybe I can do somethin with that but I would prefer to calculate a value for linear velocity. I found a formula that rearranges mgh = KE + rotational KE into something like root(gh) but it makes no sense since the height change could be the same but at different velocities...
If you're trying to find a formula for the acceleration this is the approach you'll want to take. Friction is indeed an unknown (along with the acceleration), but that is okay. You have two equations F=ma and τ = I α.
Start with a force diagram and remember that, when evaluating the torque, you must specify your axis of rotation. Note that this is also important for the moment of inertia!
I question the I = 1/2mr2. That is the moment of inertia of a solid cylinder or disc about its center of mass. Is the can hollow?
Yes the can is hollow, should I use mr2 instead? Anyways I believe static friction is something like μmg but how would I find the coefficient of friction? :(
Yes. If the can is open on both ends. I would say that if it is only open on one end you should use the moment of inertia of the hollow cylinder (hollow can) PLUS the moment of inertia of the single end (solid disc). Perhaps you don't have all of the information for this... If so you'll be better off using the hollow cylinder formula.
No. Static friction is variable. It will always adjust itself to be equal and opposite to the force along the surface in the other direction. On FLAT ground the MAXIMUM force of static friction is μmg. Leave the force of friction as an unknown 'f.'
  • · Replies 33 ·
17K
  • · Replies 32 ·
  • · Replies 45 ·
  • · Replies 17 ·
