Find area of parallelogram given vertices
Zashmar
Find the are of the parallelogram ABCD where A is (1,2,-3), B is (-1,3,-4) and D is (1,5,-2)
Area=\left|AxB\right|
where A and B are the vectors AD, and AB respectively.
I have calculated AD to be= (0,-3,-1)
and AB=(2,-1,1)
∴ to find \left|AxB\right| I subbed the two vectors into a 3x3 matrix. Finding the magnitude of th result, I calculated the area to be 2x\sqrt{11}. The Anser is 2x\sqrt{14}. What have I done wrong?
and AB=(2,-1,1)
You likely made an error in finding the vector product \vec{A}\times \vec{B}.
BTW: Use " \times " for ## \times\ ## .
Well I will show you how i did it because I cannot find an error:
i j k
0-3 1
2-1 1
^that is a matrix
So i got:
-2i+2j+6k
=Sqrt 44
=2 sqrt 11
i j k
0-3 1
2-1 1
^that is a matrix
Shouldn't the second row of your matrix be ##(0, -3, -1)## instead of ##(0, -3, 1)##?
Likes 1 person
and AB=(2,-1,1)
The first vector is actually DA, and the second is BA.
AD is -(DA) = <0, 3, 1>
and AB = -(BA) = <-2, 1, -1>.
i j k
0-3 1
2-1 1
^that is a matrix
The vectors you have in the OP will work. (They both have the sign error Mark pointed out.) .. but they will give ## 2 \, \sqrt{14} \ ## .
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
