physninj
- 37
- 0
two very long coaxial cylinders. Inner has radius a and is solid with charge per unit length of λ. Volume is also uniform but not defined by a parameter. Outer is hollow with inner radius b and outer radius c. Outer cylinder is a conductor with charge per unit length of -2λ. Find E(r) for all r in terms of given parameters. you can also view attached picture.
∫E.dA=qenclosed/ε0
I'm hung up right away on what to do with the inner radius from 0->a I've got the left side of the equation I think, but I don't know how to get qenclosed in terms of r, if it needs to be. I expect to integrate on that part. Anywho here's where I'm at.
E2∏rh=(1/ε0)∫dq
I've got λ=dq/dh where h represents the length of the cable being considered. All the examples seem to use charge density rather than charge per unit length, using this gives me:
E2∏rh=(1/ε0)∫λdh which is not in terms of r. I suppose I could still integrate it and cancel h on both sides, let me know if that's wrong.
E2∏rh=(λh/ε0)→E2∏r=(λ/ε0)
E(r)=λ/(2∏r*ε0)
Is this wrong for any reason? It doesn't feel right to not use the radius on the right side.
