Find electric field a distance from a charged sheet
To find the electric field 9 mm from a charged sheet with a charge density of 5 μC/mm², the formula E=σ/2ε0 is used. The initial calculation yields E=2.8 x 10^5 N/C, but the expected answer is approximately 5.6 x 10^11 N/C. The discrepancy arises from incorrect unit conversions; charge density must be converted to SI units (C/m²) for accurate results. The correct conversion leads to E=2.82 x 10^11 V/m. Understanding the significance of a "sheet of infinitesimal area" is also a point of confusion in the discussion.
rocapp
For a sheet of infinitesimal area, find the electric field 9 mm from the surface if the charge density is 5 μC/mm^2.
E=σ/2ε0
E=(5x10^-6 C/m^2)/(2*8.85x10^-12)
= 2.8 x10^5N/C
I know the correct answer is about 5.6x10^11 N/C, but I'm not sure why. Probably units? I'm not sure how to get N/C at the end when I'm given microcoulombs/mm^2 to begin with. Please help! Thank in advance.
Yes, this is a problem with the units.
You need to convert σ into SI units, ie C/m2
(5C/m^2) / (2*8.85x10^-12C/Vm) = 2.82x10^11 V/m
E=σ/2ε0
= 2.8 x10^5N/C
What on Earth is a sheet of infinitesimal area ?
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
