Find Energy from canonical function
  • Thread starter Thread starter boddhisattva
    Energy Function
boddhisattva
Let Z=2T/s + 1/3 + s/(30T) be the partition function of a quantum rotor at s/T->0. Show that
U=nk(T-s/6-s^2/(180T)
1/(1+x) = 1 -x
U=-kT^2(\partial _{T} ln(Z) )
Hence
U=-kT^2 [2/s - s/(30T^2)] / [ 2T/s + 1/3 + s/(30T) ]
I tried dividing upper and lower equation by 2T/s and use 1/(1+x) = 1 -x but cannot find the result.
Are you sure the negative sign on the right side is correct?
Try factoring out 2T/s in the denominator.
Note that you want to get a result for U that is good to second order in the small quantity s/T.
So, you might need to include the next higher order in the approximation 1/(1+x) = 1 - x
1/(1+x) = 1 -x
I think that it should be U=nkT^2(\partial _{T} ln(Z) )
Hence
I got their answer. You are doing it right but, as already pointed out, maybe you forgot to keep the expansion to second order, which you have to do here,
1/(1-x) = 1 + x + x^2 + \ldots
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
