Find equation for thermodynamic process
The discussion centers on finding the equation for a thermodynamic process where the specific heat is defined as C = R/(\gamma - 1) + αP. Participants clarify that C represents the specific heat capacity of the process, distinct from constant pressure or volume values. The first law of thermodynamics is suggested as a method to proceed with the calculations. There is a debate about the validity of using ΔQ = nCΔT across different processes, with consensus that it applies universally. Ultimately, the original poster successfully arrives at the correct answer.
utkarshakash
Find the equation of the thermodynamic process in which specific heat of the gas is given by
C=\dfrac{R}{\gamma -1} + \alpha P
I can write
C=C_v + \alpha P
But I don't know how to proceed ahead. What does C mean here? Is it specific heat capacity at constant pressure or volume? Any help is appreciated.
I can write
C=C_v + \alpha P
Is α supposed to be the coefficient of volumetric thermal expansion? Because, if it is, it's units are wrong.
Chet
Chet
No. It's a positive constant.
Hi utkarshakash
utkarshakash said:
I can write
C=C_v + \alpha P
Correct...
C is the specific heat capacity of the process .It is neither of the two (i.e at constant pressure or volume ) .It is not that the heat capacity has to be either CP or CV .
Apply the first law of thermodynamics .
Tanya Sharma said:
Hi utkarshakash
Correct...
I get
m(C_v + \alpha P) dT = nC_vdT + \int P dV
where m=mass of gas
How do I calculate the work done in the process?
where m=mass of gas
I think it should be
nCdT = nCVdT + pdV
Write Cv in terms of C and take n =1 for sake of simplicity.
nCdT = nCVdT + pdV
But ΔQ=nCΔT is valid only when C=Cp. In general ΔQ=mCΔT
:rolleyes:
ΔQ=nCΔT is applicable in every process.
Likes 1 person
Tanya Sharma said:
:rolleyes:
Thanks. I got the correct answer.
