Find f(t) given an inverse Laplace transform
JJBladester
Find f(t).
L^{-1}\left\{\frac{s}{s^{2}+4s+5}\right\}
I tried completing the square to get to the solution and I ended up with:
L^{-1}\left\{\frac{s}{s^{2}+4s+5}\right\} =
L^{-1}\left\{\frac{s}{(s+2)^{2}+1}\right\}
Then, I used the inverse of a transform for cosine and the first translation theorum:
coskt = L^{-1}\left\{\frac{s}{(s^{2}+k^{2})}\right\}
L\left\{e^{at}f(t)\right\} = F(s-a)}
with a being -2 and k being 1 to get an answer of:
e^{-2t}cos(t)
However, I was wrong. The book had the following answer:
e^{-2t}cos(t)-2e^{-2t}sin(t)
My question is where does the -2e^{-2t}sin(t) come from?
Are you sure that is all of the Laplace transform?
\frac{s}{(s+2)^2+1}=\frac{s+2 -2}{(s+2)^2+1}
now when you split that into two fractions, the one with s+2 in the numerator will give the cos term and the other will give the sin term, assuming I remember laplace transform correctly.
Good call, I knew that was missing but for some reason failed to mention it =(
Aaaaha! That looks like a Calc II trick coming back to light. The chapter in my Differential Equations book dealing with Laplace Transforms does talk a lot about fancy algebra techniques like partial fraction decomposition, rearranging constants, and completing the square. I just forgot this one in particular.
Thanks for the explanation.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
