Find general solution from recurrence relation, done most of work
itunescape
2xy" + y' + xy =0 xo=0
find the indicial equation, recurrence relation and series solution.
I've done most of the work but i don't know how to use a recurrence relation to obtain a y1 and y2 series solution.
this is what I've done:
xy= sum (n=2 to infinity) an-2 x^(r+n-1)
y'= sum(n=1 to infinity) (r+n) an x^(r+n-1)
2xy''= 2*sum (n=2 to infinity) (r+n) (r+n-1) an x^(r+n-1)
indicial equation:
rao + 2r(r-1) ao=0
r+ 2r^2-2 = 0
r= 0 , r=1/2
{(r+n) (r+n-1) an + (r+n) an + an-2}=0
an= - an-2/ (r+n)(r+n-1)
r=0:
ao=1 a1=0
a2= a0/2*1
a3= a1/ 3*2
a4= a2/4*3
a5= a3/5*4
what kind of pattern could i get out of this? the denominator looks like an n! but not exactly. Where can i go from here to get a y1 ?
It seems to be that it should be easy to show, unless I'm mistaken, that
a_{odd} = 0
a_{even} = 1/n!
indicial equation:
rao + 2r(r-1) ao=0
r+ 2r^2-2 = 0
r= 0 , r=1/2
r=0:
ao=1 a1=0
a2= a0/2*1
a3= a1/ 3*2
a4= a2/4*3
a5= a3/5*4
The first thing you should have done is write out a few terms explicitely.
If a0= 1 then a2= a0/2*1= 1/2. If a1= 0, a3= a1/3*2= 0. a4= a2/(4*3)= (1/2)1/(3*4))= 1/(2*3*4), a5= a3/(5*4)= 0/(5*4)= 0, a6= a4/(6*5)= [1/(2*3*4)][1/(6*5)]= 1/(2*3*4*5*6).
Do you see now?
yes I do, thank you very much. So to get y2 all i have to do is change from r=0 to r=1/2 and keep ao=1 and a1=0 right?
Yes.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
