Find Gravitational Force Component on Inclined Plane - 388.5 N, 36.1°
To find the gravitational force component on an inclined plane, the weight of the box (388.5 N) must be resolved into two components: one perpendicular and one parallel to the plane. The perpendicular component is calculated using mgcos(36.1°), while the parallel component uses mgsin(36.1°). The discussion emphasizes the importance of drawing a diagram to visualize the forces involved. Understanding vector resolution is crucial for solving the problem effectively. The key takeaway is that the gravitational force acting down the incline is represented by the parallel component, mgsin(36.1°).
arsnmilan4
a box weighing 388.5 N on an inclined plane that makes a 36.1 degree angle with the horizontal.
compute the component of the gravatational force on the inclined plane in N
would you find the gravatiational component by finding the x and y components?
Thanks for any help
You must show some work in order to get help. Have you drawn a diagram with all of the forces shown? Can you explain where are you stuck?
I drew a diagram, and I found the mass of the object which was 39.64 kg but i am not sure if i need that calculation. I am tring to look at how to get started so that I can solve the problem.
I hope you are familiar with vectors.
mg is perpendicular to the ground but it makes the angle of 36.1 with the inclined plane.
Hence resolve mg. The component perpendicular to the plane would be mgcos36.1 and that which is parallel to the plane would be mgsin36.1
Yea I am familiar with vectors, so the the component of the gravatational force acting down on the inclined plane is the component that is perpendicular to the plane?
mgcos36.1
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
