Find gravitational potential energy if at point
To find the gravitational potential energy at point B, the relationship between the distances from the center of the Earth to points A and B is crucial, with B being twice the distance of A. The gravitational potential energy at A is given as -2MJ, which can be expressed using the formula Eg = -G*M*m / r. By substituting the distance for B (2rA) into the potential energy formula, the potential energy at B can be derived. The algebraic manipulation confirms that the potential energy at B is -MJ, reflecting the change in distance. This approach effectively clarifies the relationship between gravitational potential energy and distance in a gravitational field.
jono240
An object is moved from A to B in the gravitational field of earth. The distance between the center of Earth and B is twice that of A. If the gravitational potential energy of the object at A is -2MJ, what is the gravitational potential energy of the object at B?
Eg = -G*M*m / r
Im stumped for where I should start. I need to find the mass or radius of orbit of this object but I can't figure out how to do that with just the gravitational potential energy given. Please help with a hint on where to start. I don't want the question answered. Thanks
If rA is the distance from the center of the Earth to A, and rb the same for B, then you know
\frac{GMm}{r_A} = -2MJ
\frac{GMm}{r_B} = ?
Use the relation between the two lengths and the first formula to get the potential energy at B.
I know that rb is 2ra
so if I just substitute the 2ra in the first equation, do I get GMm/2ra = -2MJ/2
Im not sure if that's algebraically correct
That's correct, you basically substituted the value for the potential energy at A into the expression for it at B (with the additional half factor)
lol alright. I wasnt sure about the algebra there.
thanks a lot man!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
