Find K for which f is one-to-one
  • Thread starter Thread starter intenzxboi
intenzxboi
f(x)= x^3 + kx^2 + 19x
So what i did was take the derivative of f(x)
3x^2 + 2kx + 19
\sqrt{}
(3x+ \sqrt{19}) (x+ \sqrt{19})
so then i can assume that 3x\sqrt{19} + x\sqrt{19} = 2kx
and then k i got to be 2\sqrt{19}
Im i right?? i feel like I'm completely lost..
f(x) is one to one if it's derivative never changes sign. f'(x)=3x^2+2kx+19 is always positive for large enough x, so you want to find the values k where f'(x) is never negative. Think about finding the minimum of f'(x) as a function of k.
k so find where f(x) is increasing
so..
3x + \sqrt{19} > 0
x + \sqrt{19} > 0
So x> (-\sqrt{19}) / 3
and x> -\sqrt{19}
Is that right??
3x^2 + 2kx + 19
\sqrt{}
What happened to k? It shouldn't just go away.
so..
3x + \sqrt{19} > 0
x + \sqrt{19} > 0
and x> -\sqrt{19}
Is that right??
No.
Go back to the derivative you found and determine a value of k that makes the derivative positive everywhere. Instead of factoring, as you have attempted (unsuccessfully) to do, you might try the quadratic formula.
k i used the quadratic formula and got
[ -2k +/- \sqrt{2k^2 - 228} ] / 6 = X
Having trouble solving for k
No, no, no. Find the minimum of f'(x). Take the derivative of f'(x) (i.e. f''(x)) and set it equal to zero. That will give you the x value of the point where f'(x) is a minimum. What is the value of f'(x) there?
You have f'(x) = 3x^2 + 2kx + 19, and you would like to find a value of k so that f'(x) > 0 for all x.
By using the Quadratic formula, so solved the equation 3x^2 + 2kx + 19 = 0, for x.
If you want 3x^2 + 2kx + 19 to not have any (real) solutions for x, you want to pick a number k so that the discriminant (the part in the radical in your work) is negative. If that happens, there won't be any real solutions to the equation 3x^2 + 2kx + 19 = 0.
What does it take for the discriminant to be negative?
Taking the 2nd derivative i get 6x + 2k = 0
so x=-2k/6
take this values into the 1st derivative and i get a long equation that ends up giving me after reducing
-k^2 - 2k/3 + 19
You have that the minimum of f'(x) is at x=-k/3. That's good. But when I put x=-k/3 into 3x^2 + 2kx + 19 I DON'T get -k^2 - 2k/3 + 19. Could you fix that up?
Opps i forgot the squared root sign.
-k^2 - (2k^2)/3 + 19
Do i set this to 0?
Do i set this to 0?
I don't agree with the first term either. It was supposed to be 3*(-k/3)^2. Sure, once you get it right, then you can set it equal to zero and use that info to figure out where it's nonnegative.
arg... okay i for some reason cancel the 3 out..
new equation gave me k^2= 19
Your algebra isn't doing so well today. 3*(-k/3)^2=k^2/3. Plus. Not minus.
yea i think i got it.. half way thru the equation i figures 3x root19 + x root19
need a minus sign
i ma start all over.. give me a sec
need a minus sign
Don't start all over! You just need a good expression for the minimum of f'(x) in terms of k. Just fix the sign problem.
No no i save the information on like 20 pages.. wanted to do it on one neat page for my records later on.
I finally got k= +/- root 57
Right. Those are the values of k for which f'(x) has a zero minimum. The minimum in general is 19-k^2/3. For what values of k is that nonnegative? +/-sqrt(57) aren't the only possible values of k.
Thank You!
I finally understand it
so if I am correct
the function x^3 + kx^2 + 19x
is one to one at
k <= - root 57 OR root 57 <= k
Other way around. -sqrt(57)<=k<=sqrt(57), right? For example, k=0 works.
Huh??
k i have
For increasing
-k^2 /3 >-19
k< +/- root 57
For decreasing
-k^2 /3 <-19
k> +/- root 57So it is a one-to-one if its either increasing or decreasing
You want to find the values where the minimum of the first derivative is nonnegative, right? Agreed? You found that the minimum of f'(x) is 19-k^2/3, ok so far? The minimum is zero at k=+/-sqrt(57)~+/-7.5. But at k=0, the minimum is 19. At k=+/-3 the minimum is 16, ok, still positive. At k=+/-10 the minimum is negative. So for say k=10, the function f(x) increases, then decreases then increases. It's not one to one. Correct?
