Find k if (4,1,k) & (5,1,-3) are perpendicular?
  • Thread starter Thread starter discy
    Perpendicular
4 replies · 2K views
discy
Vectors
find k if (4,1,k)τ & (5,1,-3)τ are perpendicular?
From the answer sheet I know the answer is k = 7
I believe I need these two but I'm not certain:
Dot-product: v*w = v1w1 + v2w2 + ... vdwd
cos θ = v*w / ||v|| * ||w||
[STRIKE]Because θ = arccos(v*w / ||v|| * ||w||) = the angle between two vectors. θ should be 90 = perpendicular.
90 = arccos ((4 * 5 + 1 * 1 + k * -3) / √(4²+1²+k²) * √(5²+1²+(-3)²)) =
90 = arccos (21-3k / √(17+k²) * √35)
90 = arccos(21-3k / √(17+k²) * √35)[/STRIKE]
cos(90) = 0 = perpendicular
[itex]\frac{21-3k}{\sqrt{17+k²} * \sqrt{35}} = 0[/itex]
what would be the easiest way to get to k = 7 ?
What you need is that cos(90)= 0! So that two vectors are perpendicular if and only if their dot product is 0.
ok. so let me reform:
(21-3k) / √(17+k²) * √35 = 0
what would be the easiest way to get to k = 7? (when I put 7 as k I get zero, so the equation is correct)
If you already knew that the dot product is 21- 3k, why even use that denominator?
The two vectors are perpendicular if and only if their dot product, 21- 3k= 0. Solve that for k?
[STRIKE]Ow yeah. I'm being stupid.[/STRIKE]
And if two vectors are parallel? [STRIKE]then the angle is, I suppose 180 degrees? What equation would I need to solve in that case?
(i'm sorry, my teacher is very unclear about these things, he puts questions on his sheets but doesn't always give the answers during class)[/STRIKE]
edit: cross-product = 0
