Calculate L using Omega, Lo = 16, and h = 1.5
  • Thread starter Thread starter eddievic
To find L using the equation ω = (1/h) ln(L/Lo - 1) with given values ω = -2.6, Lo = 16, and h = 1.5, the calculations lead to L = 16.32384. The discussion highlights the importance of using the correct notation for natural logarithms and suggests that substituting constants later in the process can help avoid round-off errors. An alternative method for solving the equation is provided, emphasizing a clearer algebraic manipulation. Overall, the solution is confirmed as correct, and the importance of notation and method is reinforced.
eddievic
Find L if...
\omega=\frac{1}{h}In(\frac{L}{Lo}-1)
Find L if omega - -2.6, Lo = 16 and h = 1.5
-2.6*1.5=In(L/16-1)
-3.9=In(L/16-1
e^-3.9=L/16-1
0.02024=L/16-1
1.02024=L/16
so L=16.32384
The correct abbreviation for the natural log is 'lower case L' and 'lower case N'. You have 'Upper case I' and 'lower case N', which is incorrect. Otherwise, your algebra appears to be correct.
Ok thanks for the help I will use the correct abbreviation in future
-2.6*1.5=In(L/16-1)
-3.9=In(L/16-1
e^-3.9=L/16-1
0.02024=L/16-1
1.02024=L/16
so L=16.32384
It's best to substitute the constants at the end of your algebraic manipulation. Doing so sooner can lead to round-off errors.
This is the way I would have done it.
$$\omega=\frac{1}{h}\ln(\frac{L}{L_0}-1)$$
$$\Rightarrow h \omega = \ln(\frac{L}{L_0}-1)$$
$$\Rightarrow e^{h \omega} = \frac{L}{L_0}-1$$
$$\Rightarrow e^{h \omega} + 1 = \frac{L}{L_0}$$
$$\Rightarrow L_0 (e^{h \omega} + 1) = L$$
Now you can replace the constants.
this makes a lot of sense thanks Mark44
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
