Find Magnetic Field of an Elliptical Solenoid | Biot-Savart Law
  • Thread starter Thread starter anothersivil
    Solenoid
anothersivil
I have to find an expression for the magnetic field of an elliptical solenoid. This is an actual solenoid sitting on the desk next to me, but even an infinite/very long solenoid approximation would be a wonderful start.
Biot-Savart law
Therein lies the problem... I've not the slightest clue where to start. I just started working in a lab at my school and the grad student here left me this problem while he's away on vacation. I've only seen Biot-Savart from my Intro to Electromagnetism class, so I'm not to savvy with it yet. A poke in the right direction would be greatly appreciated!
I tried looking up elliptical cylindrical coordinates and when I saw all of the sinh's and cosh's I got kinda scared... but I did come across something else. I found that for an elliptical loop of current, the magnetic field is:
u[0] = 4*pi*10^(-7)
I = current
a = semi-major axis
b = semi-minor axis
k = sqrt(1-a^2/b^2)
B = (u[0]*I)/(pi*a)*E(k), where E(k) is a complete elliptical integral of the second kind.
E(k) = int( sqrt(1-k^2*sin^2(theta)), theta = 0..pi/2).
Given the specs that I have, k=0.826, I found an integral table (CRC standard mathematical tables, 18th edition) and found that E(k) = 1.372.
Plugging in my other numbers (this is assuming 1 amp of current), I got the field to be:
B = 1.065 gauss.
This seems to be somewhat correct since the current for a circular loop of about the same size is pretty small too. Now I need to find a way to incorporate the number of turns (in this case, 1010 turns) into my equation so that I can get an idea of how strong the elliptical solenoid will be. Any ideas?
I'm fairly sure that the magnetic field inside an ideal (infinite) solenoid is independent of the shape of its cross section. What matters are the cross-sectional area and the sheet current density.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
