Find mechanical energy lost when a cyclist goes down a hill
The discussion revolves around a cyclist coasting down a hill, analyzing the work done by gravity and the mechanical energy lost due to air resistance and friction. The problem involves concepts from mechanics, specifically energy conservation and transformations between kinetic and potential energy.
  • The original poster calculates the work done by gravity using kinetic energy differences but expresses uncertainty about how to determine the energy lost to air resistance and friction. Other participants inquire about the purpose of the calculated work and the conditions under which no work would be needed.
The discussion is ongoing, with participants exploring the relationship between kinetic and potential energy. Some guidance is provided regarding the energy exchange concepts, but there is no explicit consensus on how to approach the calculation of energy losses.
Participants are navigating the implications of energy conservation and the effects of non-conservative forces like air resistance and friction, with some questioning the assumptions made regarding potential energy in the scenario.
Phys121VIU
A cyclist has a speed of 5 m/s when she beings to coast down a hill, as shown in the figure. At the bottom of the hill, her speed has increased to 12m/s. the mass of the cyclist plus bicycle is 75kg.
a) Calculate the work done by gravity on the cyclist and bicycle.
b) Calculate the mechanical energy lost because of air resistance and friction. Explain.
I found the work done(part a):
Work = ΔK = Kf - Ki
Work = [(1/2)mvf2 - (1/2)mvi2]
Work = [(1/2)(75kg)(12m/s)2 - (1/2)(75kg)(5m/s)2]
Work = (5400 - 937.5)Nm = J
Work = 4463 J
What I don't understand is how to find the air resistance and friction..i just need an idea of where to start
Thanks!
What is the calculated work used for?
What speed would cyclist have when there would be no need to do work?
Gravity? I'm not sure what your asking..
Let's say there would be no need to do any work. In that way, you would only have exchange between kinetic and potential energy. On top of the hill, your PE would be max and your KE would be min. On bottom of the hill, your KE would be max and your PE would be min. But such exchange is not possible because you have some losses and you need to do some work. Now I see that you neglected the potential energy.
  • · Replies 31 ·
  • · Replies 38 ·
