Find Power & Current Info for DC Battery 9V/1.5V
The discussion focuses on finding information about the power and maximum current for 9V and 1.5V DC batteries. The maximum current varies based on battery size and chemistry, with suggestions to provide more details for accurate information. Resources like PowerStream and Battery University are recommended for further research. Ultracapacitors are mentioned as a high-power alternative, though they have lower energy density compared to chemical batteries. The conversation also touches on the choice between primary and secondary batteries, as well as the option of using AC adapters for power needs.
tefavolc
i need link for the power or the maximum current for dc battery 9 and 1.5 voltage ..if anyone know please share it ??
There is no one answer for this. It depends on the size of the battery and the type (chemistry) of the battery. You need to give more details.
This site has some good data on AA batts:
http://www.powerstream.com/AA-tests.htm
I thought they dealt with other sizes too, but I can't find anything in quick search mode. Maybe a little more digging will turn it up.
If maximum power is truly your only concern, and not duration (i.e energy), then ultracapacitors are the leading technology though their energy density is an order of magnitude less than a chemical battery. So the first question is 'maximum current' for how long? See, e.g., here:
http://en.wikipedia.org/wiki/File:Supercapacitors_chart.svg
If you truly want a battery, can you use a throwaway (primary) or do you need a rechargeable (secondary) battery?
This site might also provide some useful background:
http://www.batteryuniversity.com/index.htm
thnx all for help
If you want power..throw avay the battery and get an ac adapter
or buy a lead acid battery of 10ah atleast
Go green think green
Ethan,
Dont forget to add me as your friend
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
