Efficient Trigonometric Identity Solution for Finding tan x
  • Thread starter Thread starter teleport
    Tan
The discussion focuses on finding tan x from the equation involving sine and cosine functions. One participant suggests using trigonometric identities to simplify the left-hand side and proposes a method involving the conversion to a quadratic equation. Another participant recommends dividing both sides by cos²(x) to facilitate solving the equation, noting that this approach reveals a clearer path to the solution. The conversation highlights the realization that a simpler method exists, which could lead to a quicker resolution of the problem. Overall, the thread emphasizes the importance of exploring different algebraic manipulations in trigonometric equations.
teleport
Find tan x if
\dfrac {\sin^2 x}{3} + \dfrac {\cos^2 x}{7} = \dfrac {-\sin(2x) + 1}{10}
Trigonometric identities.
I have tried removing the cos squared on the LHS by using
\cos^2 x + \sin^2 x = 1
and then using
\sin^2 x = \dfrac {1 - \cos(2x)}{2}
then using
\cos(2x) = (\cos x + \sin x)(\cos x - \sin x)
Noticing the RHS equals
(\sin x - \cos x)^2
and factoring with what is now the LHS, would eventually give me an expression similar to
a\sin(2x) + b\cos(2x) = c
where a,b,c are constants. If there is now a way to solve for any of sin(2x) or cos(2x), I can then get tan(2x) and hence, tanx.
This solution has been so long, that it all sounds very suspicious to me. I have a hunch there should be a much easier solution. Thanks for any help, but please, don't post a solution.
teleport said:
Find tan x if
Your method looks okay. But if you are searching for a better one, you may consider dividing both sides by cos2(x), since it's trivial to see that cos(x) = 0 is not a solution to the equation.
It becomes:
\frac{\tan ^ 2 x}{3} + \frac{1}{7} = -2 \frac{\tan x}{10} + \frac{1}{10 \cos ^ 2 (x)}
\Leftrightarrow \frac{\tan ^ 2 x}{3} + \frac{1}{7} = - \frac{\tan x}{5} + \frac{1}{10} \left( 1 + \tan ^ 2 x \right)
Can you go from here? :) Hint: It's a quadratic.
Ouch! That hurts. I didn't even think of dividing by (cosx)^2, otherwise I would have seen it right away. It was right in my face all the time:eek:. If it were a shark, I would be ...
