Solving a Geometry Problem: Area of a Circle with a Wedge
In summary, the area of the larger circle without the wedge or the smaller circle is 105π/2 square centimeters.
i made a pretty picture but i can't get it to upload :frown:
oh well...i'll try to explain it
a circle of radius 3cm is inside a circle of radius 8cm (in the middle). On top of these two circles is a wedge (i think...it's like a triangle except curved at the end to fit the edge of the larger circle) which has an angle of 45 degrees at the centre of the cirlces.
what is the area of the larger circle without the wedge or the smaller cirlce?
I got an answer...but i'd like to see if it's right or not, and also if there's a simpler way of doing it.
This is what I did:
area of the bigger cirlce = 64pi
area of the smaller circle = 9pi
area of the larger wedge = integral of x - (64 - x^2)^1/2 between 0 and 8
i haven't actually learned how to do that algebraicly, but there's this nifty little function on my calculator... :biggrin:
i get 50.27cm squared
(can someone show me how to integrate that function anyway just for the hell of it?)
area of the smaller wedge = integral of x - (64 - x^2)^1/2 between 0 and 3
= 23.42cm squared
(64pi - 9pi) - (50.27 - 23.42) = 145.95cm squared
so...
Q1. Did I do it right?
Q2. If not, how do i do it?
Q3. If so, is there an easier way i could have done it?
Q4. How do you integrate non-linear functions raised to a power?
ta in advance
Mathematics news on Phys.org
area of the smaller wedge = integral of x - (9 - x^2)^1/2 between 0 and 3
= 2.57cm squared that shouldve been...
but it's wrong anyway...
why?
if the middle of the circles was the origin, take one of the lines formed by the wedge as the x axis, then the other line is y = x because of the 45 degree angle. the curved line at the end was part of the cirlce, so it had the equation y = (9 - x^2)^1/2
so then why shouldn't the integral of x - (9-x^2)^1/2 between 0 and 3 be the area of the smaller wedge?
The area of a "wedge" of angle θ (measured in radians) in a circle of Radius R is &theta R2/2. That's just the area of the circle πR2 time the fraction θ/2π.
Since your larger circle as radius 8 cm, a 45 degree= π/4 radian angle cuts out a wedge of area (π/8)(64)= 8π square cm.
In the smaller circle, of radius 2 cm., that same wedge cuts out an area of (π/8)(4)= π/2 square cm. We need to know that since we don't want to subtract that area twice!
The entire circle of radius 2 cm has area 4π square cm so the area of the small circle NOT in the wedge is (4- 1/2)π= 7π/2 square cm.
The large circle has area 64π square cm. so the area left after removing the wedge and the circle (an upside down keyhole?) is 64π- 8π- 7&pi/2= 105π/2 square centimeters.
1. How do you find the area of a circle with a wedge?
To find the area of a circle with a wedge, you will need to know the radius of the circle and the angle of the wedge. Then, you can use the formula A = (π*r^2) * (θ/360) where A is the area, r is the radius, and θ is the angle in degrees.
2. What is the formula for finding the area of a circle with a wedge?
The formula for finding the area of a circle with a wedge is A = (π*r^2) * (θ/360), where A is the area, r is the radius, and θ is the angle in degrees.
3. Can I use the same formula to find the area of a circle with any size wedge?
Yes, the formula A = (π*r^2) * (θ/360) can be used to find the area of a circle with any size wedge, as long as you have the correct values for the radius and angle.
4. How do I convert the angle from degrees to radians?
To convert an angle from degrees to radians, you can use the formula θ (in radians) = θ (in degrees) * (π/180). So, if you have an angle of 45 degrees, the equivalent in radians would be 45 * (π/180) = π/4.
5. What is the significance of the angle in the formula for finding the area of a circle with a wedge?
The angle in the formula represents the portion of the circle that the wedge covers. For example, if the angle is 90 degrees, the wedge would cover one quarter of the circle, and the area would be one quarter of the total area of the circle. This angle is essential in determining the size of the wedge and the area it covers.
  • General Math
  • General Math
  • General Math
