Find the change of internal energy of the air.
To find the change in internal energy of air in a car tire, the formula U=5/2nRT is used, considering air as a mixture of diatomic gases. The number of moles (n) is calculated using the ideal gas law, resulting in approximately 3.7 moles. After determining the final temperature from the pressure change, the internal energy is calculated to be around 2500 J, which aligns closely with the textbook answer of 2537 J when accounting for significant figures. The discussion emphasizes the importance of using the correct gas constant and significant figures in calculations. Overall, the calculations confirm the expected change in internal energy based on the given conditions.
MaiteB
A car rubber has the volume 50 liters when it is bloated in a pressur 1.8 atm and in a temperature 293 K. After some hours of journey as an effect of friction the pressure will become 2atm. Find the change of internal energy of the air inside the rubber (U)
U=3/2nRT
I thought to sue the formula U=3/2nRT, but I don't know the n.
Don't forget the ideal gas law. Also, in the formula for U, are you sure the fraction is 3/2? Nitrogen and oxygen are diatomic gases.
Ok but how can I find the U with this compound of gases like air?
I am writing my solution: pV=nRT=>n=(1.8*10^5*0.05)/(8.31*293)=3.7
1.8/293=2/x=>x=325.5555
U= 5/2* 3.7*8.31*(325.56-293)=2500, but in my book the answer is 2537J
Looks good. Some of the data in the problem is given to only 2 significant figures. So, the textbook should have rounded the answer to 2 significant figures which agrees with yours.
Likes MaiteB
If you use 1.01325 x 105 for atm you find a better number. Your calculation is correct.
Likes MaiteB
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
