Find the changes in entropy for the water and for the ice
  • Thread starter Thread starter Soaring Crane
    Entropy Ice Water
The discussion focuses on calculating the change in entropy for a system where 1.0 kg of water at 20°C is mixed with 1.0 g of ice at 0°C. The entropy change for the ice is calculated as 1.223 J/K using the heat of fusion and the temperature in Kelvin. The entropy change for the water is found to be -13.6 J/K, accounting for the heat lost as it cools down. The net change in entropy for the system, combining both values, is determined to be -12.377 J/K. This indicates that the overall entropy of the system decreases as the ice melts.
Soaring Crane
In a well-insulated calorimeter, 1.0 kg of water at 20 C is mixed with 1.0 g (.001 kg) of ice at 0 C. What is the net change in entropy of the system by the moment the ice completely melts? The heat of fusion of ice is 3.34 x 10^5 J/kg.
I must find the changes in entropy for the water and for the ice, then find the net change.
Net change = /_\S1 + /_\S2
This is what I did so far:
S_ice = (mL)/T, where Q = mL
S_ice = [(3.34 x 10^5 J/kg)*.001 kg]/[273 K] = 1.223 J/K ?
How do I find the change in entropy for H2O??
Thanks.
You have found the \Delta S for the ice. The \Delta Q for the water is just the loss of heat to the ice. It takes place at 293K (we can see that there is not a significant temperature reduction - about .1 degree). So:
\Delta S_{H_2O} = -334/293 = -1.14 J/K
AM
To find the change in entropy for water, we can use the equation S = Q/T, where Q is the heat absorbed or released and T is the temperature in Kelvin. In this case, the water is being heated from 20 C (293 K) to 0 C (273 K), so the change in entropy for water would be:
S_water = Q/T = [(1 kg)(4186 J/kg*K)(273 K - 293 K)]/293 K = -13.6 J/K
Since the ice is at 0 C and the water is at 20 C, we can assume that the heat lost by the water is equal to the heat gained by the ice. Therefore, the net change in entropy for the system would be:
Net change = S_water + S_ice = -13.6 J/K + 1.223 J/K = -12.377 J/K
So the net change in entropy for the system is -12.377 J/K.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
