Find the coefficient of restitution
The problem involves two equal balls in contact on a table and a third equal ball striking them simultaneously, with the goal of determining the coefficient of restitution. The context includes concepts from momentum conservation and the coefficient of restitution in collisions.
  • Participants discuss the expressions for the coefficients of restitution and question the application of momentum conservation. There are suggestions to reconsider energy conservation principles and the definitions related to the coefficient of restitution.
Some participants have provided guidance on checking the expressions for the coefficients of restitution and the momentum conservation equations. There is recognition of potential errors in the original poster's approach, particularly regarding the definitions and assumptions made in the problem.
There is a mention of the collision being inelastic, which affects the application of energy conservation. The problem statement did not specify the nature of the collision, leading to some ambiguity in the discussion.
utkarshakash
Two equal balls are in contact on a table. A third equal ball strikes them simultaneously and remains at rest after the impact. Show that the coefficient of restitution is 2/3.
I have attached an image for clarity of problem. Please open it.
Conservation of Momentum
Let the mass of balls be m and coefficient of restitution be e.
[itex]\frac{v_{2}}{vcosθ_{2}} = e[/itex]
Also,
[itex]\frac{v_{1}}{vcosθ_{1}} = e[/itex]
Applying Conservation of Momentum along X-axis
[itex]v=v_{1}cosθ_{1}+v_{2}cosθ_{2}[/itex]
Along Y- axis
[itex]v_{1}sinθ_{1}=v_{2}sinθ_{2}[/itex]
Substituting the value of v1 and v2 in the above equation
[itex]evcosθ_{1}sinθ_{1}=evcosθ_{2}sinθ_{2}[/itex]
[itex]cosθ_{1}sinθ_{1}=cosθ_{2}sinθ_{2}[/itex]
Multiplying 2 on both sides
[itex]sin2θ_{1}=sin2θ_{2}[/itex]
Rearranging and simplifying
[itex]2cos(θ_{1}+θ_{2})sin(θ_{1}-θ_{2})=0[/itex]
[itex]θ_{1}+θ_{2}=\frac{∏}{2}[/itex]
[itex]θ_{1}-θ_{2}=0[/itex]
[itex]θ_{1}=θ_{2} and θ_{1} = \frac{∏}{4}[/itex]
Now substituting the value of θ1 in equation of momentum along X-axis
[itex]1=e(cos^{2}θ_{1}+cos^{2}θ_{2})[/itex]
[itex]e=\frac{1}{cos^{2}θ_{1}+cos^{2}θ_{2}}[/itex]
[itex]e=\frac{1}{2cos^{2}θ_{1}}[/itex]
[itex]e=1[/itex]
What's wrong here? :confused:
I will say first to reconsider your expressions for the coefficients of restitution. Also check the momentum conservation. Furthermore it may help to consider energy conservation as well. As this gives a further restraint on the values in the problem.
energy conservation principle can't be applied here because the collision is not elastic. I also suspect something wrong in my expressions for coefficient of restitution. But I can't figure out what is it. Also I don't think that momentum conservation equations are wrong.
Well if it is indeed an inelastic collision than you are correct. It was not specified in your problem statement. You're off by a minus sign in one of your momentum conservation equations. The definition of the coefficient of restitution is fractional value of the ratio of speeds before and after a collision. You should be able to find the error by just considering this definition and looking at your expressions for, e.
If the 3 balls are identical and the collisions occur simultaneously. You can immediately deduce that.
The lines of impacts of both collisions pass through the centres and therefore,
[tex]\theta_1=\theta_2=\frac{\pi}{6}\\<br /> and\\<br /> v_1=v_2[/tex]
Then your answer is therefore [itex]e=\frac{2}{3}[/itex]
Hey, why didn't I think it earlier! Thank You.
13K
