Find the coordinates of a and b
  • Thread starter Thread starter chrisdk
    Coordinates
chrisdk
We are given two vectors \vec{a} i \vec{b}. We know that
2\vec{a}-3\vec{b}=\begin{bmatrix}0\\-17\end{bmatrix}
\vec{a}+4\vec{b}=\begin{bmatrix}11\\19\end{bmatrix}
I have tried to solve this through a set of equations with two unknown, but don't really know how to do that:
\begin{cases}2a-3b=[0,-17]\\a+4b=[11,19]\end{cases}
Thank you in advance for any clues:)
As you can see from the original equations, the x and y components of the vectors are independent.
Try to express what you know as a matrix equation: a matrix containing the components of the unknown vectors, multiplied by a matrix of some numbers equals another matrix of some numbers.
You can solve just as you would any pair of equations, just being careful to keep both components on the right. For example, if I had "2a- 3b= " and "a+ 4b= " whether they were number, vectors, matrices, or whatever, I would think "If I multiply the second equation by 2 and subtract, I will eliminate the 'a'!"
Okay, 2a- 3b= [0,-17] and 2a+ 8b= [22, 38]. Subtracting the first from the second, 11b= [22-0, 38+17]= [22, 55] and now I see that b= [2, 5].
Oh, yeah, that's simpler than what I had in mind:
\begin{bmatrix}a_1 & b_1\\a_2 & b_2\end{bmatrix}\begin{bmatrix}2 & 1\\-3 & 4\end{bmatrix}=\begin{bmatrix}0 & 11\\-17 & 19\end{bmatrix}
\begin{bmatrix}a_1 & b_1\\a_2 & b_2\end{bmatrix}\begin{bmatrix}2 & 1\\-3 & 4\end{bmatrix}\begin{bmatrix}2 & 1\\-3 & 4\end{bmatrix}^{-1}=\begin{bmatrix}0 & 11\\-17 & 19\end{bmatrix}\begin{bmatrix}2 & 1\\-3 & 4\end{bmatrix}^{-1}
\begin{bmatrix}a_1 & b_1\\a_2 & b_2\end{bmatrix}=\begin{bmatrix}0 & 11\\-17 & 19\end{bmatrix}\begin{bmatrix}\frac{4}{11} & -\frac{1}{11}\\\frac{3}{11} & \frac{2}{11}\end{bmatrix} = ...
Moderator's note:
Thread moved to Homework area. Homework assignments or any textbook style exercises are to be posted in the appropriate forum in our Homework & Coursework Questions area. This should be done whether the problem is part of one's assigned coursework or just independent study.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
