Calculating Displacement with Sine Waves
  • Thread starter ScienceGeek24
  • Tags
    Displacement
In summary, the displacement of a sinusoidal wave with amplitude 0.2m and frequency of 0.18rad/m and 90rad/s at position x=0 and t=0 is -0.141m.
ScienceGeek24
164
y=0.2msin[(0.18rad/m)x+(90 rad/s)t - pi/4]
What is the displacement at position x=0 and t=0?
y(x,t)=Asin(kx-wt+phi)
y=0.2m[0.18-90]=-0.199m
the answer is -.141 m help?
Where did the 0.18 come from? x = 0.
And don't mix radians and degrees. And don't forget the sine.
As the above post said, the displacement is 0. This is because at x=0, t= 0, so everything in the sin function becomes 0. Sin of 0 is 0. Hence the displacement =0
the displacement can't be 0 because the answer sheet says is -.141m and when i put x=0 i still get the same asnwer -0.199m don't get it.
The value of x is 0, not the displacement (which is the y value).
Show exactly what you did.
Silly me, forgot the phase of the thing. Since everything else in the sin =0, then sin(-pi/4) =-1/(sqrt(2) multiply this by 0.2 and you get your answer of -0.141m.
Never mind what i was doing was wrong i was subtracting .18-90 and the sine of that time 0.2m is .199m
but what hypnosam is doing seems right
I did y= 0.2sin[0.18(0)+90(0)-pi/4] but i just don't know how he got 0.707 when inmy calculator i get 0.013 for sin(-pi/4) wth.
Make sure you're using radian mode.
got it thanks!
1. What is displacement?
Displacement is a vector quantity that measures the change in position or distance between an initial point and a final point.
2. How is displacement different from distance?
Distance is a scalar quantity that measures the total length of a path, while displacement is a vector quantity that measures the shortest distance between two points.
3. How do you calculate displacement?
Displacement can be calculated by subtracting the initial position from the final position, taking into account the direction of the movement.
4. Can displacement be negative?
Yes, displacement can be negative if the final position is behind the initial position. This indicates that the object has moved in the opposite direction of its initial position.
5. What are some common units for measuring displacement?
The most common units for measuring displacement are meters (m) and kilometers (km). Other units such as feet (ft) and miles (mi) can also be used depending on the scale of the displacement.
