Find the Eigenvalues and eigenvectors of 3x3 matrix
The discussion focuses on finding the eigenvalues and eigenvectors of a 3x3 matrix A based on provided equations. The eigenvalues identified are λ1=6 with eigenvector u1=[1, 2, 1] and λ2=3 with eigenvectors u2=[1, -1, 1] and u3=[2, -1, 0]. The eigenspace corresponding to λ2 has a dimension of two, indicating that all linear combinations of u2 and u3 are also eigenvectors for λ2. The discussion concludes that the matrix A is not diagonalizable due to the presence of repeated eigenvalues with multiple eigenvectors.
  • Understanding of eigenvalues and eigenvectors
  • Familiarity with matrix operations and determinants
  • Knowledge of linear algebra concepts such as eigenspaces
  • Ability to work with 3x3 matrices
  • Study the process of diagonalization of matrices
  • Learn about the geometric interpretation of eigenvalues and eigenvectors
  • Explore the implications of linear dependence and independence in eigenspaces
  • Investigate the conditions for a matrix to be invertible based on its eigenvalues
Students and professionals in mathematics, particularly those studying linear algebra, as well as data scientists and engineers working with matrix computations and transformations.
Michael_0039
Assume a table A(3x3) with the following:
A [ 1 2 1 ]^T = 6 [ 1 2 1 ]^T
A [ 1 -1 1 ]^T = 3 [ 1 -1 1 ]^T
A [ 2 -1 0]^T = 3 [ 1 -1 1]^T
Find the Eigenvalues and eigenvectors:
I have in mind to start with the Av=λv or det(A-λI)v=0....
Also, the first 2 equations seems to have the form Av=λv:
So maybe, u1= [ 1 2 1 ] with λ=6 and u2= [1 -1 1] with λ=3 .......but what about 3rd ?
Why don't you get A explicitly at first ?
Matrix A is not given, only those equations.
Those equations are equivalent to a product relation of 3X3 matrices say
AB=C
So explicitly
A=CB^{-1}
...But I see getting explicit A is not a straight forward way
Correct.
The second and third means, that the eigenspace to the eigenvalue ##3## has dimension two. It is spanned by ##(1,-1,1)^\tau## and ##(2,-1,0)^\tau.##
So the answer will be:
λ1=6 with u1=[ 1 2 1 ]T
λ2=3 with u2=[ 1 -1 1 ]T and u3=[ 2 -1 0 ]T
Yes.
I mean, almost.
All linear combinations of ##(1,2,1)## (i.e. all multiples of) are eigenvectors to the eigenvalue ##6,## too.
All linear combinations of ##(1,-1,1)## and ##(2,-1,0)## are eigenvectors to the eigenvalue ##3,## too.
@Michael_0039 note my edit. You've been too fast.
If ##v_1,\ldots,v_n## are all eigenvectors to the same eigenvalue ##\lambda ## then
A\left(\sum_{k=1}^n \alpha_k v_k\right)=\sum_{k=1}^n\alpha_k A(v_k)=\sum_{k=1}^n\alpha_k \lambda v_k=\lambda \cdot \left(\sum_{k=1}^n\alpha_k v_k\right)
all linear combinations are eigenvectors to the eigenvalue ##\lambda, ## too.
So for the 2nd question: Is A reversible or/and diagonal ?
The answer if A-1 exists is λ12≠0 and is non-diagonal because λ2 has reached one time but has 2 eigenvectors (?)
Michael_0039 said:
So for the 22nd question: Is A reversible ...
What do you think? Hint: not reversible implies not injective. Now, what does not injective mean?
Michael_0039 said:
... or/and diagonal
Are those three vectors linearly independent? If so, they will be a basis. How does ##A## look like according to that basis?
By subtraction I observe
A[-1,0,1]^T=[0,0,0]^T=0[-1,0,1]^T
which suggests ##\lambda=0,3,6## in all.
fresh_42 said:
Correct.
The second and third equations tell us that (2, -1, 0)^T - (1, -1, 1)^T = (1,0,-1)^T \in \ker A.
Thank you. My mistake! I mistook it for ##A(2,-1,0)=(2,-1,0).##
@Michael_0039 Forget my posts. I was thinking about a different situation.
  • · Replies 33 ·
  • · Replies 16 ·
10K
