Find the electric field strength inside a solid sphere.
The problem involves finding the electric field strength at various distances from the center of a uniformly charged solid sphere with a radius of 25 cm and a total charge of 14 µC. The discussion centers around the application of Gauss's Law and the correct interpretation of electric field equations within and outside the sphere.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the relationship between electric field strength and distance from the center of the sphere, questioning the use of the formula E = (kq)/r^2 inside the sphere. They discuss the need for Gauss's Law to find the electric field strength and consider the charge enclosed within a Gaussian surface.
Some participants have provided guidance on using Gauss's Law and calculating charge density. There is an ongoing exploration of how to determine the charge enclosed at different distances, with multiple interpretations of the problem being discussed. Participants express uncertainty about the calculations and seek clarification on the concepts involved.
Participants note the uniform distribution of charge and the implications for calculating charge density. There is a focus on the volume enclosed by Gaussian surfaces at specified distances, which affects the calculations of electric field strength.
_F_
A solid sphere 25cm in radius carries 14uC, distributed uniformly throughout its volume. Find the electric field strength (a.) 15cm, (b.) 25cm, (c.) 50cm from the sphere's center.
R = .25m
Q = 14 * 10^-6 C
p = q/(volume)
E = (kq)/r^2
a.) I have absolutely no idea where to even begin here. This is what I really need help with. I'm not sure if the answer relates to the other two distances, so i'll show how I got those. For some reason, E = (kq)/r^2 fails here.
b.) E = (kq)/r^2 = (9.0*10^9 Nm^2/C^2)(14*10^-6 C)/(.25m)^2 = 2.02 * 10^-6 N/C
c.) E = (kq)/r^2 = (9.0*10^9 Nm^2/C^2)(14*10^-6 C)/(.50m)^2 = 504 * 10^3 N/C
The field inside a uniformly charged sphere is not kq/r^2. To determine the actual relationship, the easiest way is to use Gauss's Law. Are you familiar with Gauss's law?
Yes I am familiar with Gauss's Law.
flux = integral(EAcos(theta)) = q_enclosed/e_0.
I'm still not sure where to go from here, though.
What is [itex]Q_{enclosed}[/itex] at r= 15cm?
I know its not 14uC. It must be something else, but I can't seem to figure out what.
Q = (e_0)*E*A ?
A = 4(pi)r^2 = 4(pi)(.15m)^2 = .2827m^2 ?
Well the 14uC is distributed uniformly throughout the sphere, so what is the charge density of the sphere then?
I would say Q/A = 14*10^-6 C * .2827 m^2 = 5*10^-5 C/m^2
But plugging that into: E = (5*10^-5 C/m^2)/e_0 = 5.59*10^6 N/C.
But my book says E = 1.21 MN/C
Can anyone point me in the right direction here?
I still can't wrap my head around this. :(If the charge density is p = q/volume. Then p = (14*10^-6 C)/(4/3*pi*(.25m)^2 = 2.14*10^-4 C/m^3
But how do I use this?
Well, [itex]Q_{enclosed}[/itex] is the charge enclosed by your Gaussian surface. For part (a), the Gaussian surface does not enclose the entire volume; and so it does not enclose the entire charge. What volume is enclosed for r=15cm? Shouldn't the charge enclosed be that volume times the density that you just calculated?
12K
  • · Replies 37 ·
13K
