Find the equations of the trajectories?
  • Thread starter Thread starter Math10
    Trajectories
Math10
Find the equations of the trajectories of y"+y^3=0.
None.
The Undamped Case:
y"+p(y)=0
v(dv/dy)+p(y)=0
integrate
v^2/2+P(y)=C
So following the formula above:
The answer I got is v^2/2+y^4/4=C, but the answer in the book says v^2+y^4/4=C. What's wrong?
Did you, blindly, followed a formula?
What makes you think the formula applies in this case?
Did you follow the formula correctly?
Did you check your algebra?
Did you check your arithmetic?
Maybe the book made a typo?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
