Find the Equilibrium temperature distribution of a PDE
Engineer913
1) What is the Equilibrium temperature distributions if α > 0?
2) Assume α > 0, k=1, and L=1, solve the PDE with initial condition u(x,0) = x(1-x)
du/dt = k(d^2u/dx^2) - (α*u)
I got u(x) = [(α*u*x)/2k]*[x-L] for Part#1 but this was told to be wrong
Part #2 I got α*u = -2, Also wrong.
Any insight how to correct this?
With the equilibrium condition you should just have a ODE.
\frac{d^2u}{dx^2}-\frac{a}{k}u=0
Yes, it certainly is! How did you get that function?
An "equilibrium" solution is one that no longer changes: du/dt= 0 so the partial differential equation becomes k d^2u/dx^2- au= 0, a linear, homogeneous, second order, ordinary differential equations. If you are taking a course in "partial differential equations", you certainly should know how to solve such an equation.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
