Find the Flux Through a Cube
  • Thread starter Bryon
  • Tags
    Cube Flux
In summary, the flux through a cube placed in an electric field with a magnitude of 3.00y is 3.993Nm^2/C. For a cube in an electric field with components of -4i + (6+3y)j, the flux can be calculated by taking the dot product of the unit vectors for each face with the electric field vector and performing the appropriate integrals.
Bryon
99
A cube, placed in a region of electric field, is oriented such that one of its corners is at the origin and its edges are parallel to the x, y, and z axes as shown to the left. The length of each of its edges is 1.1 m.
(a) What is the flux through the cube if the electric field is given by E = 3.00y?
3*1.1^3 = 3.993
flux = 3.993Nm^2/C
(b) What is the flux through the cube if the electric field is given by E = -4i + (6 +3y)j
flux = ?
flux = E dot A = |E||A|cos(theta)
-4(1.1)^3 + (6+3*1.1)*1.1^2 = 5.929Nm^2/C
which isn't correct. I though that you have to find the flux in the x and y directions then just sum them up to get the total flux. Do I need to find the angle between the magnitude of the vectors?
In (a), the electric field is strictly in the x-direction (parallel to the xy plane), although its magnitude has a y dependency. The important thing, though, is that the direction of the flux lines will be perpendicular to the front and back faces of the cube (where the front and back are assumed to be the faces parallel to the yz plane), and parallel to all other faces.
Things in (b) are a tad more complicated, with the field having distinct x and y (i and j) components. Write the outward pointing unit vectors for the dA area elements for each cube face and take the dot product with the field vector (Cartesian dot product). That will tell you what integrals you'll need to perform to sum up the flux.
Would the dot product be like the following:
[-4i + (6 +3y)j] dot y^2
which would just equal (6+3y)(y^2) then just integrate this from 0 to 1.1?
For the front face it would be [-4i + (6 + 3y)j + 0k] dot [1i + 0j +0k] = -4
For the left side face it would be [-4i + (6 + 3y)j + 0k] dot [0i -1j +0k] = -6 - 3y, where y = 0 for the left side face.
Do the rest accordingly.
The flux through the cube would be the same as the flux through any surface enclosing the cube. In this case, the cube is parallel to the x, y, and z axes, so the normal vector of any face would be parallel to the electric field. Therefore, the angle between the electric field and the surface would be 0 degrees, and the cosine of 0 degrees is 1. So the flux through the cube would simply be the magnitude of the electric field multiplied by the area of one face of the cube, which is (1.1 m)^2 = 1.21 m^2. Therefore, the flux through the cube would be:
flux = |E| * A = (|-4i + (6+3y)j|) * 1.21 m^2 = (√(4^2 + (6+3y)^2)) * 1.21 m^2 = (4 + √(36+36y+9y^2)) * 1.21 m^2
Note that in this case, the electric field is not constant throughout the cube, so you cannot simply multiply the magnitude of the electric field by the volume of the cube to get the flux. Instead, you must consider the electric field at each point on the surface of the cube and then integrate over the entire surface to find the total flux.
What is flux?
Flux is the measure of the flow of a physical quantity through a given surface.
How is flux calculated?
Flux is calculated by taking the dot product of the surface area vector and the vector field representing the physical quantity.
What is a cube?
A cube is a three-dimensional shape with six square faces of equal size.
How do you find the flux through a cube?
To find the flux through a cube, you must first calculate the surface area of each face, then calculate the dot product of the surface area vector and the vector field at each face, and finally sum up all of the dot products.
Why is finding the flux through a cube important?
Finding the flux through a cube is important in many scientific fields, such as fluid mechanics and electromagnetism, as it allows us to understand the flow of physical quantities through a given surface and make predictions about the behavior of these quantities in different scenarios.
