Calculating Frictional Force on a Ladder Against a Wall
In summary, the man is one fourth of the way up the ladder, which has a mass of 20 kg. The ground has a force of 7.8 x 10^2 N acting on it, and the man is exerting a force of 2.0 x 10^2 N. The total force on the ladder is 50 N.
Dark Visitor
215
I need help on this problem. I thought I knew how to get it, but this is a multiple choice question, and my result wasn't any of the answers.
An 80-kg man is one fourth of the way up a 10-m ladder that is resting against a smooth, frictionless wall. If the ladder has a mass of 20 kg and it makes an angle of 60 degrees with the ground, find the force of friction of the ground on the foot of the ladder.
Multiple choice answers:
*7.8 x 10^2 N
*2.0 x 10^2 N
*50 N
*1.7 x 10^2 N
*100 N
Here is the equation I thought was relevant, and I used:
Tnet = (distance from ground to top of ladder where it meet wall)n - (distance from foot of ladder to man)mm - (1/2 x 10m)ml = 0
(ml = mass of ladder, mm = mass of man)
Which for my attempt, came out like this:
Tnet = 8.66n - 80 kg(2.5 m) - 20 kg(5 m) = 0
(To get 8.66, I did 10sin60)
Which, since I solved for n, gave me:
n = (80(2.5) + 20(5))/8.66
n = 34.642 N
which was wrong. Any help showing me where I went wrong and what I need to do would be appreciated.
We know that:
[tex]\Sigma T = 0[/tex]
[tex]\Sigma F = 0[/tex]
What is the best choice for the axis of rotation?
The bottom of the ladder (where the ladder touches the ground)?
If we decided to take the bottom point of the ladder as our axis of rotation would the friction force produce any torque?
No, at least I don't think it would.
Correct, it wouldn't produce a torque because the angle between the lever arm and the friction force would be zero.
[tex]T = L\times F = |F||L|\sin{\theta }=0[/tex]
What is a more ideal point to place our axis? One in which the friction force does produce a torque.
At the center of the ladder? Or the top, where it touches the wall?
Where it touches the wall will help the most because it will save us from having to calculate the force the wall exerts on the ladder.
So, which forces are acting on the ladder? And where along the ladder are these forces being applied? (What are their lever arm values?)
There is a normal force on the ladder by the ground, a normal force on the ladder by the wall (which you said cancels out?), static friction between the ground and the ladder, the weight of the ladder, and the weight of the man.
I do not understand lever arms, so I don't know how to explain your last request.
Before we continue let's explain why the normal force on the ladder by the wall cancels.
What is the angle between the force vector and the lever arm? (lever arm is just another term for "distance from axis of rotation to the force.")
Oh, now that makes more sense to me. Thank you.
I would say 150 degrees because the ladder makes a 30 degree with the wall. But I think I may be wrong because that doesn't explain why it cancels out.
150 degrees is the angle between the ladder and the wall (outside the triangle, inside the triangle it is 30). What is the angle between the force normal to the wall and the lever arm?
90 degrees?
Normal to the wall goes straight through the axis of rotation. right?
Yes, so it would be 90 degrees?
Anyone want to help me finish this problem? I need more help, and I need it by tomorrow night.
What is the definition of "force of friction"?
The force of friction is the resistance force that opposes the motion of an object when it comes into contact with another surface.
How is the force of friction calculated?
The force of friction can be calculated by multiplying the coefficient of friction (a value that represents the roughness of the surfaces in contact) by the normal force, which is the force exerted by the surface on the object.
What factors affect the force of friction?
The force of friction is influenced by factors such as the roughness of the surfaces in contact, the weight of the object, and the type of force (e.g. static friction vs. kinetic friction).
Why is the force of friction important to consider in scientific experiments?
The force of friction plays a crucial role in determining the movement and stability of objects, as well as the amount of energy required to move them. It is important to understand and measure the force of friction in order to accurately predict and control the behavior of objects in experiments.
How does the force of friction contribute to everyday life?
The force of friction is responsible for many everyday phenomena, such as walking, driving, and gripping objects. It also helps to prevent objects from sliding or slipping on surfaces, making movement and interaction with our environment possible.
